How to intall live feed from battery to trunk?
Old Feb 20, 2006 | 10:50 AM
Silverbullet767's Avatar
Default How to intall live feed from battery to trunk?
Hi, I have a 1999 (march) A4 1.9 TDi. And I would like to install a sub in the trunk. The battery is located under the window at the passenger side, How would I route the cables to the inside of the car, then through to the trunk??
Is there anything I need to look out for when disconnecting the battery??
Any help would be great, apoligies if this has been covered before, this is my first post
Old Feb 20, 2006 | 11:02 AM
Jestnomen's Avatar
6th Gear
Default RE: How to intall live feed from battery to trunk?
The best way is to run the power wire through the ECU box. If you open up the black box on the left hand side of the hood (drivers side in the US) you'll see a big rubber grommet. If you pass your power lead through that and down with the wire bundle it will come out by the drivers foot area. From there it is best to run the wire under the kick plates in the door sills. Doing that is really really easy it only took me like 5 minutes to push the wire up underneath. Make sure you have your radio theft code if you disconnect the battery.
Old Feb 20, 2006 | 11:17 AM
Thanks, I'll have a look for it. Wont the current from the live wire disrupt the sensitive ECU wiring though??
Old Feb 20, 2006 | 01:58 PM
cary12's Avatar
ORIGINAL: Silverbullet767
You won't have any trouble as long as you have the right connections and fuses. Make sure you install a good fuse for whatever job you are doing.
Old Feb 20, 2006 | 02:01 PM
quattrosedan's Avatar
....with a wire and fuse....
Old Feb 20, 2006 | 10:24 PM
sandnsnow24's Avatar
FYI running amp wires is a pain in the a$$. If you don't know anything about stereo's i recommend getting the help of someone who does so you can watch and learn..... so you don't mess anything up. I've installed tons of systems and I'm glad i watched someone frst cause there's alot of details you need to know about first, and you wont know them just by looking at it.
You don't need to pay anyone, jsut find a friend nearby or somehting that has done it before.
Old Feb 20, 2006 | 10:38 PM
Jestnomen's Avatar
6th Gear
It's pretty easy on an Audi. Once you remove the ECU cover it's fairly obvious what needs to be done.
I wouln't think a constant DC line can induce interference in adjacent wires.
Old Feb 21, 2006 | 06:24 AM
Thanks for your help guys, especially the post 'with a wire and a fuse!'
Bring on the Vibe sub!
Old Feb 21, 2006 | 01:06 PM
You are right Jestnomen, for the power wire to induce any currents in surrounding wires, you would have to be pushing a sh*tload of power through it and the thick rubber surrounding it would have to disappear, all because that magnetic field falls as you get further away by the square of the distance........physics II for ya!
Old Feb 25, 2006 | 10:43 PM
Ok, ran the cables to just the rear seats, how the hell do i get it though to the trunk?? I popped off the rear seat bottom, and i need tools to take the backs off, do i need to find a route though this way, or is there an easier way????
