How long is the life expectancy of an OEM battery?
Old Aug 10, 2005 | 01:32 AM
dudley doright's Avatar
Default How long is the life expectancy of an OEM battery?
I have 2001 1.8TQ and I believe it still has the original battery. What is the life expectancy and how would you know if the battery is going bad? I left the cabin overhead light ON for an hour and my battery drained to 9V. I think it should have gone low that quick.
Does anyone use a different battery than the OEM? If so, what do you use?
Old Aug 10, 2005 | 01:47 AM
yellowa4's Avatar
Member
Default RE: How long is the life expectancy of an OEM battery?
just got my battery replaced today. had the stock battery since purchase (october 1999 for 2000 A4). lasted me almost 6 years.
the biggest clue for me was the start... battery just died overnight.. had enough to start a couple of times but after the third day i needed a boost. no warning however.. it just happened
stock audi battery cost $165 CAD... easy enough to replace.. just make sure the dealer charges it for you before you take it home.
B
Old Aug 10, 2005 | 09:48 AM
david9999's Avatar
Battery will last 4 or 5 years with care and topping up the cells twice a year with distilled water. PEPBOYs or sears sells replacement batteries.
Old Aug 10, 2005 | 11:29 AM
ORIGINAL: david9999
Does Die Hard have an actual replacement?
TheDoc46
Nov 24, 2010 11:43 AM
zakario
May 1, 2008 02:38 AM
cellardoor
Sep 13, 2006 02:24 PM
cellardoor
Sep 12, 2006 04:56 PM
kurbople
May 20, 2006 01:20 AM
