how low can you go?
how low can you go?
so im wanting to slam my ride, but have a lack of money to get the $600+ coilover kit, so ive been looking at eibach, tein, etc.. lowering springs. which do you prefer? and how low will they really drop me and how noticable is the drop?...will i need to roll the fenders or do anything to prevent rubbing?
RE: how low can you go?
with msot springs, you will lower aount an inch form the sport suspension setting (not sure what you ahve)
you wont have to do anyhting to fenders uless you go super low, which you wont find unless u get like homosexual slprings
the only problem people run into with these is that you can blow your dampers because of the increased spring rate. if you have sport suspension, you will msot likley be okay. if you dont, you will probly be oky for a bit, but i highly suggest waiting a bit and saving up for coilovers. In my experiance, i find the feel of solid, well done dampening form shocks much better than the feel of high springrate with low dampening rate. but to each his own. (also, the only reputable companies i know are einback, tein, adn H&R, H&r i recommend most)
FU(K again, all in ^^^ may be fu(ked up due to durnkkkkkk mistah f.a.b. concert
you can go 2 in da fron and 1.5 in the without having to roll da fenders (you may rub a bit)
just to let you know...I DO NOT recommend lowering on stock shocks....especially if you don't have sport suspension...
well, best of luck to you....
I was just tearing up some curvy hills this evening. the exhaust freed upa little more power, but at 155k miles, my suspension feels a little squishy now too. let me know how you make out with that kit if you get it. I def need to do that when i chip the car.
my advice is save your money for the better quality stuff -what you want - not what you can afford today. if you want it, then you'll find a creative way to make it happen.
