How many quart of oil do I need?
Old Feb 22, 2006 | 08:07 AM
707782y's Avatar
Default How many quart of oil do I need?
For a year 2002 Audi A4 Quarttro 3.0, V6, about how many quart of oil do I need for a oil change and filter change?
I'm using mobil 1 0w-49, and mann filter.
Old Feb 22, 2006 | 11:28 AM
2k2nyc's Avatar
Default RE: How many quart of oil do I need?
6.3 quarts
Old Feb 22, 2006 | 08:13 PM
j_ripper19's Avatar
the person in front of me is correct. U can pour almost 6 liters on the thing (6.3 qts), but only fill until the last 1/2 qt, then check the level. Engine will missfire if too much oil is used - do not overfill!!
Old Feb 26, 2006 | 04:16 PM
dankhound's Avatar
3.0 liters are noisy on startup right after an oil change. It will make alot of noise for a second or two after startup. Dont worry about it its normal.
Old Feb 26, 2006 | 05:49 PM
Russ03A4's Avatar
ORIGINAL: 707782y
Just a suggestion if you're really picky about your car: Check out Amsoil or Cosworth Oil. Not always easy to find but it's what the pros use.
Old Dec 28, 2007 | 08:57 AM
moe485's Avatar
WHat oil type to you reccomend??
Old Dec 30, 2007 | 01:43 AM
oldblu's Avatar
While we're on the subject and I am reminded, how much oil do you use for the 2.8L V6? And is a fram filter with Castrol High Mileage ok to use? Or should I spend the extra buck and buy
a. K&N oil filter
and/or
b. synthetic oil (Mobil 1)?
Keeping in mind I'm meticulous about my car and I'm not worried about how long each oil change lasts.
Also, should I use RESTORE with the oil change and fuel injector cleaner everytime? ...I just bought my A4 and don't want to Eff anything up..
Old Dec 30, 2007 | 08:48 AM
BaconBait's Avatar
Stick to a Mann or Mahle oil filter and get the oversized version.
Use synthetic oil. Mobil 1 is good, Royal Purple and Amsoil are rumored to be the very best.
Use quality 91+ octane fuel and you won't need injector cleaner.
Old Jan 3, 2008 | 10:22 PM
oldblu's Avatar
I've never heard of Mann or Mahle...where do you get these? Not in my local autozone.
Old Jan 3, 2008 | 10:46 PM
tdn's Avatar
tdn
my two favorite places to order anything car related are
autopartswarehouse.com and germanautoparts.com
