how many turbos
Old Jan 14, 2008 | 06:14 PM
chaos92287's Avatar
Default RE: how many turbos
hell yeah, why don't we fab up some ITB's and stick a turbo on each one[:-]
Old Jan 14, 2008 | 06:19 PM
A4speed's Avatar
ORIGINAL: SouRce4
i was thinking about quad-turbo... sounds like a better idea
flame on
Old Jan 14, 2008 | 06:52 PM
CAB509's Avatar
6th Gear
ORIGINAL: chaos92287
best idea ever, ITB's with turbo's, you could use the ones off of the Veyron
almost as good as the exhaust to turbo inlet idea some vette owner had.
01afour's Avatar
ORIGINAL: SouRce4
now theres a guy that should work for audi. a turbo for each cylinder, now thats gotta add some hp. and if you wanna go really crazy you can get some of those 'turbos' that mount to the end of the exhaust. i think we may have stumbled upon something here.
Old Jan 14, 2008 | 07:18 PM
marlonduval's Avatar
Member
ty for the imput guys .. But now lets say i just wanted a bigger turbo how one of u guys mentioned . Where would i get my hands on a gt30 or larger and wat chip should i get with that
Old Jan 14, 2008 | 07:22 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: qUaTtRoA4
I think your best bet will be a single big fukn turbo....like a Gt30 or langer...which'll be about the same size as 2 KO3's...
it would be in the same league as a 2871r, but with worse spool.
He could run sequetial turbos, say k03 and a 30r, but the spool on gt turbos are fast enough to negate the need for them
Old Jan 14, 2008 | 07:25 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: marlonduval
atpturbo.com longitude hardware kit. Base is a 28rs and then you can increase the size to whatever. Then you will need atleast 630cc injectors and the file to go with them
Old Jan 14, 2008 | 07:26 PM
  #18
chaos92287's Avatar
think you should read through this- https://www.audiforums.com/m_700266/tm.htm
Old Jan 14, 2008 | 07:40 PM
  #19
Member
yea ok one of u guy said something else that interesting what if I want to actually run sequetial turbos how possible would that be
Old Jan 14, 2008 | 07:42 PM
  #20
cincyTT's Avatar
I'm make believe
ORIGINAL: cincyTT
