How often is a radiator flush to be done?
Old Mar 4, 2006 | 05:04 AM
apg96's Avatar
Default How often is a radiator flush to be done?
I was at oil max getting my oil changed (M1 0w-40 and i brought the OEM filter) just b/c i didnt have the time to do it myself b/c of work and school. And they pitch stuff, and teh guy tried a radiator flush. Now i know that he will try and sell me anything to giv ehim more money. But i havnt done it since i got the car about 13,000 mi ago. And i ahve had to top off the coolant a lil, so how often should it be done. Ill be either doing it (if i can find time) or bringing it to my mechanic, not oil max.
Old Mar 4, 2006 | 05:14 AM
TroyS's Avatar
Default RE: How often is a radiator flush to be done?
What year is it?
Old Mar 4, 2006 | 05:19 AM
apg96's Avatar
Default 99
99
Old Mar 4, 2006 | 05:49 AM
luvin_the_rings's Avatar
Default RE: 99
i have a 98 and audi says that its sealed for the whole life of the car, not necessary to change the coolant at all
if there's a leak, fix it and top off..
Old Mar 4, 2006 | 07:28 AM
TroyS's Avatar
Default RE: 99
Yup its lifetime fluid, but make sure no one has put the green stuff in like they did on mine. Also, i've heard some opine that even the red/purple stuff should be changed every 100k.
Old Mar 4, 2006 | 11:31 AM
Jestnomen's Avatar
6th Gear
Default RE: 99
Most mechanics recommend changing the coolant every 2 years. ONLY use Pentosin G12 mixed 50/50 with distilled (if you can get distilled deionized) water. Coolant can become corrosive as the alkalinity decreases.
Old Mar 4, 2006 | 12:23 PM
techbod's Avatar
Default RE: 99
2 years minimum its not for life filled its (antifreeze) 50/50 mix , radiator is part of the cooling system
Old Mar 4, 2006 | 04:48 PM
apg96's Avatar
Default RE: 99
so when i have my 90k mi tune up i may want to have it flushed?
Old Mar 4, 2006 | 05:56 PM
techbod's Avatar
Default RE: 99
yes and change the thermostat
Old Mar 4, 2006 | 09:14 PM
Jestnomen's Avatar
6th Gear
Default RE: 99
ORIGINAL: apg96
You've had your timing belt changed right?
