how to remove radio
Lol When I installed my alpine I used 2 fingernail files and a small knife, you have to be crafty. Once you see/feel what is holding it in it makes it alot easier, and possible to do it with a knife and some files
r these these prongs that need to be realeased in order to get this thing out, all mine are realesed but still in the way do i need to push em off to the side and just yank it out or are there more prongs
[IMG]local://upfiles/21867/45B9BC0E32424FFBA6A328C5DAC972D4.jpg[/IMG]
no you dont, stick 2 in on one side and pull, using a pick or something like that wedge it in that side. then do the other side.
ORIGINAL: JohnnyBravoA4
its its a double din you need 4 of the tools not just two.. i have two and i need to buy two more to remove mine..
Removing and installing “symphony” radio
Special tools and workshop equipment required
t Radio release tool -T10057-
– When renewing radio -R-, select “Replacement” function for appropriate control unit in “Guided Fault Finding”.
To do so, use the vehicle diagnostic, testing and information system -VAS 5051-.
– Switch off all electrical equipment.
– Remove ignition key.
Removing
– Insert radio release tools -T10057- into slots on radio -R- until they engage. Pointed ends of grips must face outwards.
– Grasp hold of grips on radio release tool -T10057- and pull radio -R- out of dash panel.
– Release and unplug electrical connectors at radio -R-.
– Press release tabs on radio -R- and remove radio release tools -T10057-.
Installing
– Plug in all connectors.
– Slide radio -R- carefully into dash panel and engage it in mounting frame.
[IMG]local://upfiles/12092/7C0C8841125744EF9F47E1976C66E34E.jpg[/IMG]
[IMG]local://upfiles/12092/D0A56D02C6F04B7A9357A6AB3C39F545.jpg[/IMG]
Removing
Installing
good luck with that, the tools get stuck some times and need to be released when you take the radio out from the side...
ORIGINAL: rayveedub
