how to remove radio
Old Dec 9, 2006 | 07:53 PM
EliteTuning1's Avatar
Default how to remove radio
yeah how do you remove the radio ina 01 a4. its the audi symphony radio, i got the faceplate off but i cant figure out how to get the whole thing out.
01a4
Old Dec 9, 2006 | 08:20 PM
01A4T's Avatar
Default RE: how to remove radio
there are four small insert holes sort of on each corner of the radio. you need a few tools to pull it out...... or you could try to find some substitute to pull it out.
Old Dec 9, 2006 | 08:26 PM
earhythmic's Avatar
yea like small zip ties or something. you can prolly find a set of the "keys" on ebay or something. stick em in and pull the entire thing out.
Old Dec 9, 2006 | 11:50 PM
JohnnyBravoA4's Avatar
its its a double din you need 4 of the tools not just two.. i have two and i need to buy two more to remove mine..
Old Dec 10, 2006 | 09:07 AM
socal_A4's Avatar
Lol When I installed my alpine I used 2 fingernail files and a small knife, you have to be crafty. Once you see/feel what is holding it in it makes it alot easier, and possible to do it with a knife and some files
Old Dec 10, 2006 | 07:28 PM
r these these prongs that need to be realeased in order to get this thing out, all mine are realesed but still in the way do i need to push em off to the side and just yank it out or are there more prongs
[IMG]local://upfiles/21867/45B9BC0E32424FFBA6A328C5DAC972D4.jpg[/IMG]
Old Dec 12, 2006 | 10:42 AM
Wrench's Avatar
Got a extra set if anyone want to buy it?
Old Dec 12, 2006 | 01:38 PM
rayveedub's Avatar
no you dont, stick 2 in on one side and pull, using a pick or something like that wedge it in that side. then do the other side.
ORIGINAL: JohnnyBravoA4
Old Dec 12, 2006 | 01:49 PM
techbod's Avatar
Removing and installing “symphony” radio
Special tools and workshop equipment required
t Radio release tool -T10057-
– When renewing radio -R-, select “Replacement” function for appropriate control unit in “Guided Fault Finding”.
To do so, use the vehicle diagnostic, testing and information system -VAS 5051-.
– Switch off all electrical equipment.
– Remove ignition key.
Removing
– Insert radio release tools -T10057- into slots on radio -R- until they engage. Pointed ends of grips must face outwards.
– Grasp hold of grips on radio release tool -T10057- and pull radio -R- out of dash panel.
– Release and unplug electrical connectors at radio -R-.
– Press release tabs on radio -R- and remove radio release tools -T10057-.
Installing
– Plug in all connectors.
– Slide radio -R- carefully into dash panel and engage it in mounting frame.
[IMG]local://upfiles/12092/7C0C8841125744EF9F47E1976C66E34E.jpg[/IMG]
[IMG]local://upfiles/12092/D0A56D02C6F04B7A9357A6AB3C39F545.jpg[/IMG]
Old Dec 12, 2006 | 01:59 PM
good luck with that, the tools get stuck some times and need to be released when you take the radio out from the side...
ORIGINAL: rayveedub
