How to replace left-side parking light?
Old Jun 3, 2007 | 01:25 PM
leadc4ge's Avatar
Default How to replace left-side parking light?
Hello there!
I have been googling and searching these forums for a couple of hours now to see if I could find any information or guidelines on how to replace a broken parking light bulb (left side) on my 2004 A4. No luck so far and what little I have found just makes me confused. From what I've read it should be possible to do yourself without removing the entire housing but I just don't see how. The headlights are of the xenon-type.
Can anyone please provide me with some advice? I do not have much experience with fiddling around in cars and my native language is not english so please be detailed.
Regards
Jörgen
Old Jun 3, 2007 | 02:03 PM
Lazer Viking's Avatar
Default RE: How to replace left-side parking light?
take out the air box
and it willl be easier to remove the headlight and replace the bulb, i belive there are two torx screw on top of the lights, and one down inside the fender behind the light.
should be fairly easy from there
Old Jun 3, 2007 | 04:11 PM
leadc4ge's Avatar
Ok, so there isn't actually a way to do it without taking out the entire housing. Once I get the headlight out, will I need to disassemble that also?
Thanks for the reply
Old Jun 3, 2007 | 10:38 PM
sdsteez's Avatar
owners manual (its in there for the b5's)
Old Jun 3, 2007 | 10:50 PM
assuming he has an 04, its not a b5
Old Jun 6, 2007 | 10:28 AM
leadc4ge's Avatar
Nevertheless I will check the owners manual (I just assumed there was nothing about it in there for some reason). But I'm counting on Lazer Viking to be right and I have to remove the entire headlight.
So, will I have to disassemble the headlight once it's out, or is it a matter of simply pulling out the broken bulb and replace it? It's just that I don't know much about xenon lights and I don't wanna break anything.
Old Jun 6, 2007 | 11:46 AM
leadc4ge's Avatar
I tried removing the headlight - 2 torx screws at top and 1 torx screw at the side (by the fan) - but I was only able to move the housing a few cm's. Is there a fourth screw underneath which I can only reach from below? I could not feel with my hand where it was still stuck. Do I need to twist the headlight in some special way to unhook it?
Old Jun 6, 2007 | 12:22 PM
ironman's Avatar
I believe there is 4 screws and the headlight should move right out its also covered you have to look for it. there are a couple DIY's on here that deal with the B6 head light removal. Look for those, and yes its jsut pulling out the lgiht i think its counter clock wise, and getting the new one, if its a HId its $$ to replace if its not go to Walmart or if your in Europe an autoparts store or dealership
Old Jun 6, 2007 | 01:05 PM
techbod's Avatar
Renewing bulb for side lights
Removing
Switch off ignition and take out ignition key.
Turn light switch to position “0”.
Headlight (left-side):
Detach cover (left-side) -1- in engine compartment.
Remove electrical connectors -1- and -2- from retainer.
Unclip retainer for connectors and pull off upwards -arrow-.
Headlight (right-side) - vehicles with 1.6 ltr. and 2.0 ltr. MPI engine:
Remove air cleaner housing
Headlight (right-side) - vehicles with 1.8 ltr. turbo engine:
Remove air cleaner housing .
Headlight (right-side) - vehicles with 2.0 ltr. FSI engine:
Right headlight - vehicles with 6-cyl. petrol engine:
Right headlight - vehicles with 4-cyl. TDI engine:
Right headlight - vehicles with 6-cyl. TDI engine:
Remove air cleaner housing.
Both sides (continued):
Release retaining clip -arrow- and detach housing cover for main beam from headlight housing.
Release headlight range control motor: at right-side headlight by turning anti-clockwise -arrow-; at left-side headlight by turning clockwise.
Note[/align]
Headlight range control motor need not be removed.
Release the two retainer tabs and pull bulb holder -arrow- out of housing.
Pull bulb for side lights out of bulb holder.
Installing
Installation is carried out in the reverse order; note the following:
Insert new bulb in bulb holder, taking care not to touch glass bulb with bare hands.
Lock headlight range control motor in position.
Secure housing cover with retaining clip.
[IMG]local://upfiles/12092/3CB0AF10FB754D0280C86FE2ACAF1A6E.jpg[/IMG]
[IMG]local://upfiles/12092/2E5C091A1F1B4A38A768151FC6BA19FE.jpg[/IMG]
[IMG]local://upfiles/12092/3928EE04D5C54A36AE38F656261E511B.jpg[/IMG]
[IMG]local://upfiles/12092/85342382299B4BF7AB9DF637A963F915.jpg[/IMG]
[IMG]local://upfiles/12092/C69A4F8AB25E4D84B62D6B4A3D9A7D71.jpg[/IMG]
Old Jun 6, 2007 | 04:32 PM
leadc4ge's Avatar
Ok, I got the headlight out after a bit of cursing (did not have great tools for reaching the 4th torx screw) only to find that the autoparts store sold me the wrong bulb. They sold me a W5W which I think is for non-xenon headlights while the correct part is named H6W. A bit annoying but at least I know how to remove the headlights now.
I'll get the correct bulb tomorrow and try again.
Thanks for your help. :-)
empiremonkey
Mar 9, 2015 05:31 AM
Portland R
Feb 15, 2014 01:48 PM
jwisinger
Dec 17, 2013 10:57 AM
Robert Gabriel
May 16, 2011 09:44 PM
mra
Oct 30, 2007 04:25 PM
