How to tell if my audi is chipped
Old Nov 13, 2007 | 01:25 AM
  #21
turbo kraut's Avatar
Tech Guru
Default RE: How to tell if my audi is chipped
ORIGINAL: 01A4T
ORIGINAL: Wildbill
supposedly your fuel economy goes up very slightly being chipped. That is if you stay out of boost and drive normally.. but thats no fun.
How does an increase of boost(AKA increase of air and fuel) result in better gas mileage? I would love to hear an explaination.........
actually it does....... but i am not one to explain it, might ask onepoint8 or cincy
i think it has to do with how the tunning changes your map settings.... blah i dunno
Old Nov 13, 2007 | 01:43 AM
  #22
pyropenguin's Avatar
ORIGINAL: 01A4T
I'm guessing that the stock fuel map is slightly rich to keep the engine safe and as reliable as possible. When you get it chipped, it leans it out slightly when you're out of boost, so if you stay out of boost you use less gas.
When you're in boost you'll use much more though.
Right? maybe? no?
edit-
Threadstarter... Just go see if you can hit 135mph, stock our cars are limited to 127 or 130, so if you can get over than then you're chipped
Old Nov 13, 2007 | 01:50 AM
  #23
chaos92287's Avatar
ORIGINAL: 01A4T
When making more power it takes less time to get up to speed and then you let off the throttle and hold that speed, so you are not boosting and using very little fuel. Also chips tend to run slightly leaner at part throttle and out of boost, while Audi sends them out running slightly on the richer side to play it safe.
NRD
Oct 9, 2010 05:22 AM
Ninety7A4
Jul 8, 2010 09:52 AM
fumoazul99
Jul 19, 2008 07:15 PM
CamGriffin
Jun 23, 2006 05:30 PM
Audinam
Jun 13, 2006 02:51 AM
