How is your audi A4 reliability after 100k?
Old Apr 11, 2011 | 08:59 PM
krooswyk's Avatar
Default How is your audi A4 reliability after 100k?
Looking at getting an Audi. A4 2003-04 Manual T 3.0L.
What are you experiences in reliability? Some folks will say not good.
Audi is made by VW, and everyone I know with a VW has electrical problems. How does the Audi fair with this?
I know about the TX issues so I would get MTX anyway.
I have read about the timing belt replace called down to 75k miles.
What else guys? How its yours?
Old Apr 11, 2011 | 10:26 PM
theflash's Avatar
Your perception of reliability would depend on what you're used to. If you've owned a Range Rover, Audi is great. If you've owned anything Japanese, you won't think the reliability is so great.
I've had 2 A4's and still have my 2.8 30v quattro manual. I've owned it for about 5 years now and have been chasing repairs for most of the time I've owned it. I do my own work so my cost per year is still low, but if I had to go through a shop or the dealer I could have payed for the car twice. I should say that where I live the car will see up to +40 c in the summer and -40 C in the winter, so my cars have to endure a much harsher life than people in warmer climates.
The 3.0 v6 is a stroked version of the 2.8 30v so I can speak directly to your situation. I bought mine trying to be more responsible/reliable without the turbo. The problem has been that some parts are more expensive or there are double the parts to replace, ie valve cover gaskets, cam chain tensioners, etc.
I haven't had too many electrical problems except for: dash info screen (do any of them last more than 5 years?), ignition switch, sunroof switch, fuel level sensor, coolant temp sensor, oil pressure sensor, discolored side mirrors due to defrost malfunction... lol. Haven't had coil-pack problems... yet. There's also 4 oxygen sensors, a before and after for both cats, 6 spark-plugs, range problems with keyless entry... so there's a few things to keep in mind.
Mechanically, yeah I'm pretty sure Audi dropped the recommended timing belt change from 100k to 70k miles. For the V6 shops charge more; an independent where I live would charger 1000 for the 1.8t and 1500 for the V6. I did it my self for under 400.
Then there's the control arms, all eight of them, inner/outer tie rods, pcv system, clutch fan, broken sunroof(guids are plastic), wheel bearings, cam chain tensioners, valve cover gasket, tensioner seals, oil cooler.
Normal things like brakes and shocks/springs could also be on the way out, but that's any car at that mileage, depending on how it was treated.
Personally, I've put much more money into my daily-driver Audi than my fun-car RX-7. Yeah, the rotary is supposed to be the unreliable one, lol! So they are definitley not better handling Corrollas with leather. They are nice, but things wear-out faster than I'd like and it really seems like it's a cascade effect. Once one thing starts going, get ready because a tonne of things go around the same time. It's hard because when it works, I enjoy it.
Oh and I'm at 105,000 miles. Yay! lol....
ArnaldoPolanco
Aug 1, 2013 01:48 PM
deneb
Feb 12, 2009 04:52 PM
Pooh
Jul 19, 2007 08:56 PM
kjr7888
Apr 19, 2007 12:58 AM
kjr7888
Apr 8, 2007 11:50 PM
