Howling noise from front
Old Jan 12, 2006 | 07:36 PM
montic's Avatar
Default Howling noise from front
I have a howling noise coming from what seems like the front right. It gets louder as I go faster. The front wheels do not move at all left to right or up and down, so I think the bearings are good. Any ideas?
Old Jan 12, 2006 | 07:55 PM
InsaneHatter's Avatar
Default RE: Howling noise from front
the turbo???? LOL
What type or "howling"
Old Jan 12, 2006 | 08:09 PM
Kellya4's Avatar
A howling will usually indicate that a wheel bearing is bad. Moving the wheel up down left or right will not tell you if a wheel bearing is bad.
montic's Avatar
Sorry its a 97 2.8 Manual quattro. I am not sure how to classify the howling. Its just gets louder with higher speed.
Old Jan 12, 2006 | 08:11 PM
I would take a venture at the wheel bearing as well....
is it constant? no pulses?
Old Jan 12, 2006 | 08:15 PM
david9999's Avatar
Sounds like a wheel bearing.
Old Jan 12, 2006 | 08:21 PM
montic's Avatar
Its completly constant. Is there a way to check for it, or is it pretty much you have to get to it to see if its bad?
Old Jan 12, 2006 | 08:37 PM
Kellya4's Avatar
It's a wheel bearing.
Old Jan 12, 2006 | 08:42 PM
BaconBait's Avatar
Make a hard right turn. If it goes away it's definately a wheel bearing.
Old Jan 12, 2006 | 08:51 PM
montic's Avatar
Is there a tech article on replacing it somewhere?
