hp out of ko4
Old Oct 11, 2006 | 02:48 AM
EliteTuning1's Avatar
Default hp out of ko4
how much horsepower do you think i could run out of a ko4 with a nice program, nice exhaust, injectors, frontmount. i want to upgrade my turbo but are the positives and negatives compared to a big turbo upgrade. and is the ko4 worth the money as apose to the bt upgrade
Old Oct 11, 2006 | 02:55 AM
VB05's Avatar
Default RE: hp out of ko4
i usually will answer questions like this...but please search, there are so many threads about this topic.
Old Oct 11, 2006 | 02:57 AM
AudiCross's Avatar
weth a k04 and extencive tuning, you may be able to pull 300 crank HP, but that would be a stretch. I think the k04 is defanitly worth it is you want a harder, longer pull, but you dont want that rape-you-in-the-a$$ pull form a BT. it is also much less straining on your car. you can also keep your stock clutch, although id recomment changing it.
Old Oct 11, 2006 | 03:04 AM
VB05's Avatar
ORIGINAL: AudiCross
hah
Old Oct 11, 2006 | 03:07 AM
VB05's Avatar
basically if you want some respectable power, but with only moderate turbolag and good low end boost then the K04 is a good choice. if you wanna really beef it up a k04 wont suffice. BT's will make much more power, but they don't spool as quickly as a K04 would.
