I AM GOING K04!!!!
Old Mar 21, 2007 | 04:02 PM
  #21
onepoint8tee's Avatar
Default RE: I AM GOING K04!!!!
ORIGINAL: ThePaintballGuy
My goal isn't to have a insanely fast car. I don't want a BT at all. All I want is a little more power and a car that is still fun to drive. I just talked with in motion and thier K04 chip will produce about 220hp and around 260ft/lbs of torque. Is that to close to the 300 to be safe?
Josh
You can get 220 hp with a regular chip, exhaust, and test pipe and similar tq.Find out if they are talking about crank hp or wheel hp. If its 220 hp to the wheels then thats not bad. Most k04 setups give you 240-265 hp at the crank i believe which would be around 200-220 to the wheels. 260 ft lbs is probably safe enough with the tip tranny without a level10 upgrade. Most times when companies are advertising hp gains they are talking about crank power, not wheel power.
Old Mar 21, 2007 | 04:07 PM
  #22
18T's Avatar
18T
ORIGINAL: onepoint8tee
nahh youll be lucky if you brake 210max with a good tune and goodies.
Old Mar 21, 2007 | 10:15 PM
  #23
Amze's Avatar
ORIGINAL: chaos92287
you may wana look into a new clutch sometime soon after
Its a worthless tip..... sigh
Buy a manual car then do this...[&o]
