I AM RETARDED
Old Jun 16, 2006 | 04:31 PM
blkapra4's Avatar
Default I AM RETARDED
whats the dif between a 710n diverter valve and a bailey unit? why do people have a 710n and a n75 race valve?
Old Jun 16, 2006 | 04:35 PM
blkapra4's Avatar
Default RE: I AM RETARDED
i would like to take back my question.... i used the search function arent you guys proud of me?
Old Jun 16, 2006 | 04:37 PM
techbod's Avatar
explain your self mate?? what are you looking for?? tell us what you think about each item, whats your input and why??
Old Jun 16, 2006 | 04:41 PM
JohnnyBravoA4's Avatar
the 710n is the stock 225hp tt, it holds more boost then stock some people like them because they are a cheaper alternative to the more expensive name brand's I have an Evo DV, our stock Dv's have a paper Diaphragm that is week and tears, the 710n is storger not sure if its paper or not. as for the n75 valve there are a few the J,K, and H comonly know as the race valce some of the programs require you to use them other dont, they tend to give you higher spikes but i have not really noticed any increas in over all boost in my set up with the non pc-16 ko4 file i just get some crazy spikes sometimes i see as high as 25 on a cool night..
Old Jun 16, 2006 | 04:49 PM
techbod's Avatar
right I get it ish cough but now turning to the air box &filter (would you go cone or panel) which ever how would you decide the pipe diameter to the throttle body?? if you go too large it effects the upper limit of torque and vica versa similar to taking the air box resonator away not to mention the exhaust??
Old Jun 16, 2006 | 04:50 PM
techbod's Avatar
basically you can gain these limits without extreme mods like turbo
Old Jun 16, 2006 | 04:53 PM
onepoint8tee's Avatar
ORIGINAL: JohnnyBravoA4
The stock DV and 710N both use a rubber diaphramm. No software "requires" you to use a different kind of N75 valve, unless its BT software which requires you to use a MBC... The software is designed to work within the parameters of whatever is already on the engine, unless its a BT and the boost needs to be manualy adjusted. People get differnt N75 valves because they have different affects on the wastegate for the turbo which can result in smoother boost delivery/spiking elimination with an added 1 or 2 psi.
Old Jun 16, 2006 | 04:57 PM
techbod's Avatar
sort of stick on mods without any consideration of internals, lazy modder I call it
Old Jun 16, 2006 | 05:01 PM
ORIGINAL: onepoint8tee
well i guess im the retarted one i thought it was paper oh well.. but i do know for a fact the dahlback programing recomends the N75 k valve.
and with my n75 h valve i didnt gain any boost its smoother but i have some issues with boost surges
Old Jun 16, 2006 | 05:14 PM
blkapra4's Avatar
so if your broke and arent even chipped yet just get the 710n?
