i could use some help...
Old Oct 25, 2007 | 07:42 PM
shelbyturbo's Avatar
Default i could use some help...
just changed the fuel filter and now the car wont start. it cranks but wont turn over. any ideas?
i double checked the direction...i disconnected the battery for about 5-10 minutes (after)...double checked the fuse.
HELP!!!
Old Oct 25, 2007 | 07:46 PM
auditech79's Avatar
Default RE: i could use some help...
Flip that bitch around and see what happens. The arrows on different model audi's are different, some go towards the motor, some towards the fuel pump.
Old Oct 25, 2007 | 08:39 PM
onepoint8tee's Avatar
How many tries did you give it? It will take up to a few tries before the fuel makes its way to the engine since you probably drained quite a bit out of the lines when disconnecting.
Old Oct 25, 2007 | 09:16 PM
I had tried a bunch of times...but when i went to take it back apart i realized had switched the two lines that run in the back [sm=oopssign.gif]. i switched them up and after a couple cranks it started up. just proves my mantra...if i've done it once, i'll probably have to do it again.
