I fixed my center armrest lid.
Old Apr 5, 2007 | 06:41 AM
zoti's Avatar
Default I fixed my center armrest lid.
Anyone interested in a write up with some pictures? It was very easy to do. Took less than 10 minutes and now the lid doesn't come out anymore.
Old Apr 5, 2007 | 10:22 AM
teppegtb's Avatar
Default RE: I fixed my center armrest lid.
Very interested in a quick write up.
Old Apr 5, 2007 | 10:34 AM
Amze's Avatar
I'd love a write up
My latch doesn't click in, its broken... the thing rattles to hell when my exahust is still cold... its annoying.
Old Apr 5, 2007 | 11:52 AM
JayDeeHiTop's Avatar
Yes please give a write up!
Old Apr 5, 2007 | 02:10 PM
zoti's Avatar
OK. My wife drives the car during the day. When she gets backI will take a picture and post how I fixed it. My problem was the hinges. The driver side flexes and cracks with time and will not hold the lid tight enough.
For now, I will give a short description of what I did.
If you take the lid out you will see that the hinges flex towards the center. The driver side one flexes too much. I drilled a hole through the center of each hinge and then put a wood screw threw the holes. I put the screws from the inside of the hinges so the screw heads face each other. I then tightened the screws all the way to make it possible to fit the lid back on.
Once the lid was in place I used a needle nose pliers to turn the screws out until the heads of the screws made contact with the piece of plastic that goes between the hinges (the piece of plastic I'm talking about is in the center of the arm rest. not the lid). What this does is push the hinges outwards and create pressure to prevent them from flexing in. You will need to undo the screws if you want to remove the lid.
I will post a picture later on.
Old Apr 5, 2007 | 11:17 PM
zoti's Avatar
Here you can see the 2 screws going through the center of the lid's hinges. Let me know if you have any more questions.
Old Sep 5, 2008 | 06:33 PM
Osurfrat's Avatar
Default Very Interested
Please send me your rightup
thanks
Jim
jrshort
Sep 3, 2010 01:39 PM
audi guru
Aug 31, 2010 03:47 PM
lateta
Jul 10, 2007 01:18 PM
mrdb85
Oct 10, 2006 07:52 PM
donsajid
Jul 10, 2006 01:17 PM
