I NEED THE FORUMS HELP!!!!!!!!!!!!
Old Apr 17, 2007 | 04:08 PM
  #21
chaos92287's Avatar
Default RE: I NEED THE FORUMS HELP!!!!!!!!!!!!
your gona have to elaborate on "weird" if you want our help
Old Apr 17, 2007 | 04:12 PM
  #22
NuYorka103185's Avatar
Okay spools really early (it sounds like a semi at around 2K rpm)and sometimes i can hear the dv shoot off while Im still accelerating.
Old Apr 17, 2007 | 04:16 PM
  #23
onepoint8tee's Avatar
ORIGINAL: NuYorka103185
I think we've had this conversation like 3 times before. Didnt you at one time take your car to the dealer, and they took out your evo dv or whatever it was and replaced it with a stock pos dv?? And hadnt you been chipped for a while, and now this, and the same ****. Have you replaced the stock dv with something that will actually hold over 15psi yet?
Old Apr 17, 2007 | 04:23 PM
  #24
chaos92287's Avatar
it should spool early, its just a k04. and ya it sounds like your dv is failing. wut kind of dv you got?
Old Apr 17, 2007 | 04:53 PM
  #25
that stock DV that was put on was on for 2 days before I had evoms replace it with another billet DV. lifetime warranty
Old Apr 17, 2007 | 07:50 PM
  #26
so its not the DV. could the N75J cause the weird performance. The evoms speacialist said go back to stock N75 cuz the J will boost too much and end up hurting the car. But then again........I had to explain to this douchebag what an N75 was so.......................................
Old Apr 18, 2007 | 08:42 PM
  #27
Okay I've noticed the fluttering is only when the car shifts. Dont know if that means anything. All I know is that if I have broken another Evo DV I am definately going ape sh*t on them. Forge is looking better everyday
DragonAether
Nov 27, 2009 06:12 PM
evan671
Sep 2, 2009 03:05 PM
FezA4
Feb 5, 2008 04:52 PM
rezurrected
Sep 21, 2006 10:22 PM
