I need help w/ a part
Old Jul 11, 2006 | 03:42 PM
Agro's Avatar
Default I need help w/ a part
I contacted a couple of those online parts places and filled in the form telling them what I needed, they both responded back basically saying "We do not have access to that part". So I am not even sure what the part number is.
I need the plastic shield that goes under the front of the car that covers the sway bar, sub frame, etc. It is held in by a bunch of plastic push pins (can i get that part # too for those?, how many does it look like are used?)
I will search around and try to find some place that can give me a good deal at that point.
Thanks!
Old Jul 11, 2006 | 03:55 PM
techbod's Avatar
Default RE: I need help w/ a part
oil drip tray no idea what the part number is but try a breakers yard first or even make your own
Old Jul 11, 2006 | 04:01 PM
acetrebo's Avatar
Can you post a picture?
Sounds like the belly pan, but am not sure by your description and "push pins" you mention.
Old Jul 11, 2006 | 04:04 PM
techbod's Avatar
yep belly pan oil drip tray same thing
Old Jul 11, 2006 | 05:38 PM
kaklexicon's Avatar
you can get the belly pan and the pins from www.ecstuning.com
Old Jul 11, 2006 | 09:14 PM
Agro's Avatar
I see some "belly pan" screws, but the actual plastic shield piece, I dont see.
It just a big black piece of plastic. It covers the entire under body of the car from rocks and crap going up there. Directly underneath it is the sub frame, the sway bar, etc. it covers all that.
Old Jul 12, 2006 | 12:38 PM
kaklexicon's Avatar
Maybe they don't have them for your year. I know they have them for 01's. Did you select your make and model and then select 'Exterior'? It should be in that section
DiscoJaker
Dec 2, 2020 02:16 AM
pzp107
Apr 21, 2014 06:27 AM
AudiTurbo
Jan 7, 2014 02:29 PM
vwjetta4me
Nov 2, 2007 12:51 PM
