i need you guys help on this one
ill tell u wat i saw..i took off the cover off the engine. then i unscrewed the first spark plug wire connector thing the one closet to you if your standing in front of the car. i pull the spark plug out and i saw oil on that and i look down inside and i see oil on top of the spark plug. like not the thing but if u look down and shake the car u can see the oil move around. i hope this helps
I just recently change my spark plugs, due to the engine misfiring...well i had the same problem with the oil around the spark plug, this is because you need a new head gasket...simple fix..hope this helps....gasket around $20 - $30
yea...go to the DIY thread....if u look, you'll see that tomritt did a post about it.....changing your valve cover gasket https://www.audiforums.com/m_61552/tm.htm
oh ok cool. another question..where else can i get those spark plug wire things. do i have to get the whole set, or can i just get one part. just the part that connects with the spark plug not the wire
