I think I fix her, Nope I was wrong!!!
Old Oct 10, 2006 | 01:57 AM
JohnnyBravoA4's Avatar
Default I think I fix her, Nope I was wrong!!!
yea so if anyone as been reading my post about my problem i have been having with the car I think i Fix it and I think i know what was going on.. Fist off I had a small boost leak, dont think it was the problem but at any rate its not there anymore. second i put the new injectors in and lowered the AFPR, now when i hit the gas my presure risses instead of going down. got in the car did a test run, she chirps all 4 tires when she spools, still a little rich need to fool around with the AFPR. now what i think was going on was my fuel pump just couldnt keep up with the demand of 5 bars of presure so it would drop off, so now the thing runs mint, even pull through all the gears and rpm range.. PC-16 here I come...
Old Oct 11, 2006 | 12:54 PM
Default RE: I think I fix her, Nope I was wrong!!!
I dont know what the deal is, its still being all retarted...
Old Oct 11, 2006 | 01:08 PM
aRIf's Avatar
how do you know you are running rich ? Vag-Com logs ?
Old Oct 11, 2006 | 01:22 PM
i dont know what it is doing but i know it was leaning out b4 because i installed a fuel presure gauge and during excelloration the presure would drop off, I installed bigger injectors lowered the Fuel presure and it corrected that problem, but i still have to tweek the AFPR till the car runs better, its a little rich, i get black smoke and it bogs down when you hit the gas
Old Oct 11, 2006 | 01:27 PM
techbod's Avatar
consider blanking the EGR valve, its a pain in the **** with turbos and clogs the system up
Old Oct 11, 2006 | 01:29 PM
what do you mean by blanking, is that the one on the tube that goes from the turbo to the airbox, to be honest I tried cleanig it out with break cleaner when i did the my air box mod right b4 most of my problems started.. if its the same thing we are talking about..
techbod's Avatar
it must be done when the engine is stone cold and ignition key not even inserted
http://images.google.co.uk/images?q=...ng+plate&hl=en
Old Oct 11, 2006 | 01:31 PM
techbod's Avatar
the EGR valve is a failed component and why the hell they leave it in there with newer cars defeats me, probably because its a cash earner with the dealers
Old Oct 11, 2006 | 01:32 PM
alright im a little slow I still dont know what the EGR looks like, and im not really sure what you want me to do with it..
Old Oct 11, 2006 | 01:33 PM
techbod's Avatar
http://images.google.co.uk/images?q=...gr+valve&hl=en
