ICM help!!!
Old May 11, 2007 | 10:30 PM
A4Tuner.'s Avatar
Default ICM help!!!
I done a test today on my ICM for fualts.
heres what i got....
L1/E1 is at1207 Ohms
L2/E2 is at 1215 Ohms
L3/E3 is at 1207 Ohms
now, is this bad or good?
what are the Ohms ment to be?
is L2/E2 fualty?
my VAG-COM codes are as follows......
P1393 / 17801[/b]
Ignition Coil Power Output Stage 1: Electrical Malfunction[/b]
[/b]
P1394 / 17802[/b]
Ignition Coil Power Output Stage 2: Electrical Malfunction[/b]
[/b]
P1395 / 17803[/b]
Ignition Coil Power Output Stage 3: Electrical Malfunction[/b]
its a 1996 Audi A4 2.8L, FWD,AT, V6, 12V.
any help would be gratefull
thanks
Old May 11, 2007 | 11:47 PM
Lazer Viking's Avatar
Default RE: ICM test
why are you checking your icm
it would be easier to check the coils / plugs.. if that dosent do anything then its your icm
Old May 11, 2007 | 11:58 PM
A4Tuner.'s Avatar
i had a misfire reconzied on cylnder 6 about a month ago, i do another VAG and the misfire diassapears leaving me with them 3 codes above.
plugs are clean.
and i dont have a VAG-COM handy to swap the coils around to see if the a misfire stays on cylinder 6.
ive tested the icm becuase i dont wont to buy new coils to find out they wernt the problem (im not made of money) and to see if the ohms is too high (which is my main question here, are them numbers too high for a V6?)
Old May 12, 2007 | 12:00 AM
A4Tuner.'s Avatar
the only problem i have is a slight vibration over 60mph.
Old May 12, 2007 | 10:08 AM
acetrebo's Avatar
Nice sig.
Why dont you clean that thing before you take a picture. Thats blasphemy.
Old May 12, 2007 | 10:36 AM
david9999's Avatar
If, during On Board Diagnostic, the diagnostic trouble codes P1393/17801, P1394/17802, or P1395/17803 ("Ignition Coil Power Output Stage 1/2/3 Electrical Malfunction") are displayed: - Replace ignition coil power output stage.
Check the wiring between the ECU and ICM for continuity. If there is no discontinuity, most likely it is the ICM
Old May 12, 2007 | 11:37 AM
A4Tuner.'s Avatar
ORIGINAL: acetrebo
Nice sig.
lol thanks.
i thought i'll be different. everyones sig has a clean audi. you wouldnt beleive i cleaned it the day before that though.
Old May 12, 2007 | 11:43 AM
A4Tuner.'s Avatar
ORIGINAL: david9999
thanks, but what is the ignition coil power output stage? the E1, E2 and E3 on theicm or the actual coil? i have all 3 stages displaying at once.
thats whats getting me confused.
i'll check thewires and wd40 the sockets.
Old May 12, 2007 | 04:16 PM
A4Tuner.'s Avatar
Default RE: ICM help!!
bump...
