Idle
Old Sep 27, 2006 | 07:09 PM
00A41.8Quattro's Avatar
Default Idle
I am having alot of problems with my car idling rough. At idle it jumps up and down and at other times it will be alright. Its weird, because when I put my A/C or heat on it rarely ever jumps idle. Anyone else ever have this problem. I changed the coildpacks on it thinkining it would be those packs but it isn't. Anyone else have any ideas? It would be greatly appreciated.
Old Sep 27, 2006 | 07:18 PM
techbod's Avatar
Default RE: Idle
basically its a load system relay ( when the aircon is on it ups the revs ) to compensate for engine electrical load so your problem is with normal idle and could be as simple as cleaning the throttle body out or a split vacuum pipe
Old Sep 27, 2006 | 08:01 PM
david9999's Avatar
Default RE: Idle
Agree, could be vacuum leak, misfire, bad plugs or idle speed sensor or dirty throttle body. scan for codes.
Old Sep 28, 2006 | 05:39 AM
Default RE: Idle
If I scan for codes that will come up?
Old Sep 28, 2006 | 05:43 AM
BadLuckAudi's Avatar
Default RE: Idle
if you scan for codes you will get a bunch of numbers the you search for those numbers and you will know whats wrong
ORIGINAL: 00A41.8Quattro
Old Sep 28, 2006 | 05:45 AM
Default RE: Idle
How do I scan for the codes? I know nothing about newer cars with problems like this.
justinclarke
Nov 25, 2010 04:03 PM
shady927
Jan 7, 2010 03:18 AM
Mean buzzen half dozen 08 A4
B7 Models
Jan 5, 2010 11:36 PM
Pontio
Dec 31, 2004 10:54 PM
