Ignition Problem
Old Aug 6, 2005 | 11:04 PM
yellowa4's Avatar
Member
Default Ignition Problem
I'm not sure what's up but here's the issue. This morning I tried starting the car and the starter barely turned over. After a bit of coaxing I got the car to start. I turned the ignition a couple of times before she started. After getting her started, my radio was in safe mode and I had to re-enter the code to get thing on. Also, my windows were a little sliggish but after driving some time they were back to normal. The battery meter showed a full charge after successfully starting the car.
Could this be a battery issue or a starter/ignition issue. When I turned off the car, I restarted it and all was fine. After leaving the car for an hour, I tried it again and the issue reappeared.
Any ideas would be appreciated? Thanks!!!
A4 2000 1.8T
B
Old Aug 7, 2005 | 12:02 AM
david9999's Avatar
Default RE: Ignition Problem
Dead battery. How old is it and when was the last time (if ever) you checked the electrolyte level in it?
Check the electrolyte level and top it up above the plates with distilled water and hook it up to a charger for 24 hours at 2 amps. If you are lucky, you will be able to recharge the battery. After you charge it. check the voltage across the battery with a digital voltmeter. it should be 12.4 Volts. If less, then you need a new battery.
Old Aug 7, 2005 | 12:18 AM
yellowa4's Avatar
Member
Thank you! I will do just that...
I had the level checked last tune up (May 2004). Hope it does the trick!
B
Jace2010
May 19, 2010 04:08 PM
persephone76
Aug 29, 2009 08:49 PM
reedo82
Aug 11, 2009 08:53 AM
VThmoney
Aug 10, 2009 05:29 PM
audijawns
Nov 28, 2005 05:18 PM
