I'm Leaking!
Old Jun 26, 2006 | 03:18 AM
Teckademics241's Avatar
Default I'm Leaking!
So I recently did the DIY clear corner and bulb mod and it looks sick I'm quite happy with it. All was good for a few days, but then moisture got into one of the headlights now it looks bad. Should I cut it open, dry it out and re seal it? Is that the only obvious answer or does someone know a trick to help me make sure it stays. I used silicone the first time to seal it. Is there something better?
Old Jun 26, 2006 | 03:22 AM
miked's Avatar
Default RE: I'm Leaking!
Silicon should have worked, you must have missed a spot. I'm still sealed after months of washing and seattle rain.
Old Jun 26, 2006 | 08:51 AM
toyolla86's Avatar
you'd think silicone would seal good. i heard it does let in moisture though. what about a good epoxy.
a clear one that you can see.
Old Jun 26, 2006 | 11:23 AM
Jestnomen's Avatar
6th Gear
It's worth a shot, but silicone when done properly is good enough. I'd just remove the back of the lights and dry them out, then reseal.
Tirrany2000
Sep 2, 2008 08:26 PM
Jc61990
Aug 22, 2008 11:48 AM
darkminotaur
Jan 3, 2008 11:51 AM
Bryceaudi
Jul 31, 2007 03:42 AM
Dudek12
Jan 21, 2007 07:23 PM
