Car still leaking
Old Aug 18, 2008 | 11:59 PM
Jc61990's Avatar
Default Car still leaking
ok seriously wtf, i filled the hole in my firewall and cleaned the drains under my battery, my car was dry for a while, then we had a bad storm for 2 days and now my car is soaked again only on the drivers side. this is getting annoying.
Old Aug 19, 2008 | 12:12 AM
sineo's Avatar
Did you clear the sunroof drains?
Old Aug 19, 2008 | 12:21 AM
Jc61990's Avatar
i looked that up, but i dont see how water can get in there if its closed. i guess when i get time ill have to clear them, but will that really flood the drivers side of my car? like its more wet in the back than the front.
Old Aug 19, 2008 | 12:25 AM
Tweaked's Avatar
The sunroof is not water-tight. It's designed so that water seeps past the seals and onto the trays and down the drain tubes. Open the sunroof and pour a cup of water down the trays towards the front and see where the water comes out (if at all).
Old Aug 19, 2008 | 12:33 AM
Jc61990's Avatar
originally i thought it was the hole in the firewall where the hood release cable comes through, i ran my amp cable through there and never filled the hole, then i had like 2 inches of standing water in my car, so i filled it with some self expanding stuff and i think water is still getting through, ill have to get a better filler, what would you guys recommend, thats like a silicon type sealer? and if thats not it, ill clear the drains in my sunroof this weekend, only time im off from work, past few weeks ive been working 40 hrs
Old Aug 19, 2008 | 01:02 AM
brrman's Avatar
I would definitely second the sunroof drains being plugged. I had to clean mine last month because the headliner was getting wet after a rain. The drains go in both directions, 2 forward and 2 backward.
Old Aug 19, 2008 | 01:05 AM
Jc61990's Avatar
my ceiling and walls are dry, its just the carpets
Old Aug 19, 2008 | 01:39 AM
auditech79's Avatar
Yeah you would notice stains on the headliner and pillars if the sunroof was leaking, my vote is that wiring you ran. You need to get yourself some clear silicone, the same they use to seal sunroofs, body plugs etc. Its designed to resist water.
Old Aug 19, 2008 | 11:14 AM
johnnythefox's Avatar
check the gasket under your ecu box as well, mine leaked and only got the drivers side floor wet like yours is
Old Aug 19, 2008 | 07:58 PM
Jc61990's Avatar
thats new one, will try that
