Installed Boost Gauge, high boost?
Old May 20, 2005 | 01:17 AM
greenday's Avatar
Default Installed Boost Gauge, high boost?
Firstly my car is a 2001 a4 avant 1.8t, sport package, 5sp, quattro, 80k on the clock. my car always felt stronger than my bros(1.8 passat, echaust, chip, etc) and i figured it was because i have the updated engine(180 vs 160 or something), i have the AWM and i think his is the AEB. all i have done is a k&n panel.
anyways i finally got my boost gauge in(routing the lines sucks) i did a diy vent gauge, i have my template done, now i just gotta glass a mold and make it cf, but thats a diff topic. when i put the gauge in and started it up it idled with vac at only about -10 to -12. boost goes up to 12psi in 1st and 2nd, up to about 13 in 3rd, haven't gone faster than that tho. so could this mean that a previous owner chipped it? how can i check? pop it open and look? faulty gauge maybe? thanks.
any input appriciated
Old May 20, 2005 | 01:28 AM
2kaudi's Avatar
Default RE: Installed Boost Gauge, high boost?
Hmm thats intresting. The owner that had my car before me had chipped it. But they removed it before i got the car. My boost was normal (around 7 to 9). Your vac is not normal though, you should be around 20 vac not 10 to 13. That makes me think you would have a leak somwhere but your boost seems to be around where it should be with the 180 hp engine (seems a little high but thats not a bad thing). You should def invest in a chip though its like night and day! good luck.
Old May 20, 2005 | 01:43 AM
greenday's Avatar
oh i forgot to mention that im at about 8000 ft elevation, so that might play a little into the vaccume readings. do chipped ecus look any different than stock ecu? as in does it say APR or GIAC or whatever on a chip somewhere? thanks guys
ps ill post pics of the carbon fiber pod assembly in a new thread when it gets finished.
Old May 20, 2005 | 03:17 AM
greenday's Avatar
ok so now im thinking its chipped even more, since now that i think of it there was a screw missing that holds the ecu cover on, so someones been in there. maybe its a newspeed .8 bar, how can i tell?
Old May 20, 2005 | 03:24 AM
BFlan2001's Avatar
neuspeed chip:
Old May 20, 2005 | 03:30 AM
BFlan2001's Avatar
giac chip:
[IMG]local://upfiles/6332/ABE59ECE4B604982BB58CE5DF7F6492A.jpg[/IMG]
Old May 20, 2005 | 03:36 AM
greenday's Avatar
hey man thanks, i will be poppin it open tomarrow, hopefully im not chipped so i have something to improve on.
Old May 20, 2005 | 09:29 AM
TomRitt's Avatar
possibly a leak in the wastegate vac line. That will cause increased boost and the low vac that you have
Old May 21, 2005 | 12:59 AM
greenday's Avatar
yeah that makes sense, i will check that out right now, thanks for the info!
ryan_siefring23
B8 Models
Dec 26, 2010 12:36 PM
Jc61990
Aug 23, 2008 10:58 PM
fuzz_duster
May 13, 2008 12:53 AM
eXecut0r
Mar 22, 2007 09:56 AM
Soley4pres
Jan 31, 2007 04:08 AM
