Instrument Cluster
Old Apr 30, 2006 | 03:13 AM
Trey25's Avatar
Default Instrument Cluster
ABS and brake light came on and I took it to a shop. The next day I started the car and noticed that neither the ABS or brake light would go on when I turned the key, plus a few of the other lights wouldn't go on. I'm thinking the "mechanic" just took the bulbs out or unhooked one of the three connectors and didn't even look at the real problem. I went back to the shop only to find out the dips%!t isn't working there anymore. So now I have no clue what he f*%#&d up back there. The ABS light probably went on for something simple as a damn sensor but I gotta go through all this s#!t. Anyways should I try to get the bulbs or I gotta get a new cluster?
Old Apr 30, 2006 | 04:17 AM
BadLuckAudi's Avatar
Default RE: Instrument Cluster
id try to get bulbs first cuz a cluster is upwards of $600
Old Apr 30, 2006 | 12:00 PM
dankhound's Avatar
Pull the cluster out and make sure all the connectors are in tight. The reason your abs light came on could be as simple as a low fluid level and as costly as a new abs module.
asutherland
Jan 22, 2010 09:58 AM
MJSCC
Sep 5, 2007 03:24 AM
Brandon2000s4
Jan 25, 2007 06:19 PM
pompous
Jan 4, 2007 12:19 AM
Kid Zelda
Apr 7, 2006 01:00 AM
