Intake and CEL help!
Old Jun 27, 2007 | 01:47 PM
stilldubbin203's Avatar
Default Intake and CEL help!
ok so i have a 99 a4 1.8t and last night i decided to do the cone filter intake conversion. All went well when i drove the car when i was done, then i came home and when i staerted it back up i had a CEL. I see that everyone is putting a breather filter on their secondary air pump hose but i dont even see mine anywhere. Could anyone tell me where this hose would be and if this could be the cause of my problem.
Old Jun 27, 2007 | 01:53 PM
onepoint8tee's Avatar
Default RE: Intake and CEL help!
I dont think all 99's had the secondary air pump. The airbox I have is from a 99 with secondary air pump and there is port on the front of the box for the hose. You would know it if you had it. The reason for your CEL will be unknown until you get your ecu scanned for the fault code, but its probably due to an over oiled filter or your maf was damaged in the process, or the wiring harness to it isnt plugged infully.
You DOhave your MAF sensor in line between the filter and turbo inlet pipe right??
Old Jun 27, 2007 | 01:55 PM
less_of_me's Avatar
I think what you are refering to is for the 2.8.
As for the CEL, just godouble check your connections. You shouldn't have an issues.
Old Jun 27, 2007 | 01:58 PM
less_of_me's Avatar
ORIGINAL: onepoint8tee
I stand corrected then....as for the secondary air pump.
Do you really think an over oiled filter would ruin his MAF in 1 drive?? That seems a little extreme.
Old Jun 27, 2007 | 02:01 PM
ORIGINAL: less_of_me
If he went crazy with the oil, and depending on how long his drive was,probably. As long as everything else is hooked back up correctly that had to be disconnected to get the airbox out, there arent that many other causes other than what I mentioned I dont think.
Old Jun 27, 2007 | 02:17 PM
i know oil isnt causing it and yes i do have my maf hooked up lol...i scanned the codes and i cant think exactly what they were but it was like manufacturer emission control and air fuel metering device something...this thing is really starting to **** me off!![:@]
Old Jun 27, 2007 | 02:19 PM
Did you put the maf in the right direction?
Old Jun 27, 2007 | 02:39 PM
less_of_me's Avatar
onepoint8tee.....i see you have a new "toy" in your sig. What is that?
Old Jun 27, 2007 | 02:43 PM
Its a mbc.
David Narez
Jun 26, 2013 09:20 AM
lukestaah
Jul 28, 2012 11:26 AM
ryanjayblair
B7 Models
May 28, 2009 05:13 PM
apg96
Jun 28, 2005 05:34 AM
