intake sensor, miss fire = engine light ? help
Old Aug 9, 2005 | 09:05 PM
brent07's Avatar
Default RE: intake sensor, miss fire = engine light ? help
yes .... the mechanic just "cleared the codes" i watched him press clear when the code came up ... he didnt do anything to the engine ... just the computer .... and it made the engine light go out ... it has brand new spark plugs ... so is the ignitor and fuel injector the only other thing that could cause the piston to miss fire ? ... and how hard would that be to fix if i wanted to do it by myself ? will the light turn off once it is fixed or will i have to get a vag-com to do that
Old Aug 9, 2005 | 09:15 PM
hoonee46's Avatar
Sorry to break it to ya, but you paid a bit much for a car with its age and miles. (got my 96 w/109k mi for 4800) You should've (or should) made them fix everything for you before you bought it.
I had a cyl4 misfire before also, here's what i did that fixed it:
plugs - spend the money... get the ones with 4 prongs... makes a difference
fed cylinders with seafoam through vac line
seafoamed gas tank
seafoamed oil...
good idea to change your plugs after seafoaming since feeding it into the cylinders tends to foul up the plugs...
hope it helps, good luck with your new baby
Old Aug 9, 2005 | 09:34 PM
brent07's Avatar
pay to much ? i got it way under blue book ... but thanks i'll try some of those things ...
Old Aug 9, 2005 | 09:41 PM
clconversion's Avatar
so what are you talkiing about dude i'm confused now
ORIGINAL: wemmington
Not to be rude but who said to"just clear the codes" ?
ORIGINAL: clconversion
most of the time just clearing the codes is just a tempereary fix the problem is still there get the codes scanned and get the problem fixed
Old Aug 10, 2005 | 02:22 PM
wemmington's Avatar
I thought you were refering to my post but I reread brents post and apparently you were repling to his. My mistake sir.
wesley7883
Jul 18, 2014 08:00 PM
talonbass
Jul 12, 2011 06:59 PM
onepoint8tee
Dec 13, 2006 10:33 PM
hugoagogo
Sep 9, 2006 10:38 AM
fish16
Jul 18, 2005 05:04 PM
