intercooler help
Old Apr 1, 2007 | 01:54 AM
Lazer Viking's Avatar
Default RE: intercooler help
is an intercooler like noz ?
Old Apr 1, 2007 | 02:14 AM
L.E.O.'s Avatar
ORIGINAL: Lazer Viking
Are you crazy? noz is short for nitros-ozmosis-zion you could probably pick some at any auto parts shop out there. Just go up and ask for some it usually comes in bottles which you use to fill up your tires. Its the lightest known gas to man and your car will pretty much float along top of the road which means less friction and therefore you go super fast. but at the cost of some steering ability thats why in the movies like fast and the furious they have a button on the steering wheel which just gives them a few shots a time for when there on the straights.
Intercoolers are a myth. I think Mythbusters and doing a show on it next week actually...
Old Apr 1, 2007 | 03:02 AM
Audi_Skydiver's Avatar
A myth??? CRAP! I just bought one on e-bay... That means I am getting something that isn't real! DANG IT! I will have to see if I can return it...
I hate it when that happens!!! GEEZ
Josh
Old Apr 1, 2007 | 03:34 AM
Bondga's Avatar
since were on the subject, with a FMIC would you have to use metal pipe or could you use silicone like the stock setup, i was just wondering cause it would be easier to get a silicone like tube than try to get perfect bends in metal pipe(just a thought might not be right)
Old Apr 1, 2007 | 04:02 AM
metal is always better, preferably aluminum for its heat dissapating abilities
you dont nessecarily need bent tubing, you can get straight pipes, with like samco elbows and the degrees you need
the rubber hoses will most likely just collapse under high boost
Old Apr 1, 2007 | 02:50 PM
The Bishop's Avatar
I think your talking about the pre-turbo rubber hose lazer.
Old Apr 6, 2007 | 09:11 AM
samzo's Avatar
Default help sort out intercoolers, turbo, ecu...
Hi, i have a 1998 1.8t quattro. New to the site and seeking answers on many topics...
Could someone take a minute and list the difference/prioritize the choices: what is best as far as money goes, installation time/hassles, and other things when choosing what to buy : better turbo? ECU? Intercooler?...intakes? seeking to improve power/performance. (budget obviously pretty low, just got the vehicle)
I only have k+n filter, iridium plugs (by the way does anyone know if they have to be gapped? ( i was told they are specially designed for this audi.)
...thanks!!!!
Old Apr 6, 2007 | 12:49 PM
  #18
The Bishop's Avatar
Default RE: help sort out intercoolers, turbo, ecu...
Obviously a bigger turbo is gonna be the best performance mod. But if you are on a tight budget, get a chip. Yea they are like $400-$500, but that will be your best increase per dollar. Front mount intercoolers and intakes are good, but usually only really improve hp once you have a bigger turbo or chip or something else to begin with. Get a chip and a boost gauge.. The gauge will be worth it's weight in gold as a diagnostic tool. and they're fun to watch.
Old Apr 6, 2007 | 07:24 PM
  #19
ORIGINAL: thebishop
YES THEY ARE!!! LOL
I almost got in a wreck the first day I had it because I kept watching the gauge instead of the road! I would hit the gas and let off really quick so it would bounce around. (I know I am weird!)
Josh
Old Apr 6, 2007 | 09:20 PM
  #20
david9999's Avatar
If you are moving up and have a tight budget, go for the GIAC chip and a 710N diverter valve. When you get some money, you can go for the K04 and GIAC programming. GIAC will give a discount on the K04 programming if you are already chipped with the K03 chip.
