Intercoolers ??
Old Nov 27, 2007 | 11:21 PM
ocielz's Avatar
Default Intercoolers ??
quick question does anybody know if the ebay frontmount intercoolers really work for chipped A4's k03 turbos and possibly later on for a k04 set up.
Old Nov 27, 2007 | 11:25 PM
chaos92287's Avatar
Default RE: Intercoolers ??
yup. go with godspeed
Old Nov 27, 2007 | 11:28 PM
The Russian's Avatar
thats what i got on mine, APR chip, and an ebay front mount... works like a charm, no heat soak, the turbo side piping is warm, and after the intercooler the piping is ice cold.
Old Nov 27, 2007 | 11:34 PM
ocielz's Avatar
wow nice to know what about for a k04 upgrade is there anything that might effect the performance?
Old Nov 27, 2007 | 11:36 PM
cincyTT's Avatar
I'm make believe
If you dont want to hack up the front and with less pressure drop, consider a tyrolsport ugsmic. Its a little more costly, ok alot more costlythan a ebay kit, but will perform better also.
Old Nov 27, 2007 | 11:41 PM
Bogie's Avatar
Looks like that fits in the stock intercooler location... and it cools better than any FMIC? Even good enough for a BT setup or just the K03 and K04?
Old Nov 27, 2007 | 11:45 PM
chaos92287's Avatar
your not gona benefit much from a k04 since you have a k03s but yeah the ebay fmic will work fine on a k04 setup
ocielz's Avatar
thatsa nice sidemount but it dosnt look as nice as a frontmount, even if its small it will be better than stock cooler. also does the intercooler from ebay need a new front bumper or can it work with stock.
Old Nov 28, 2007 | 12:03 AM
chaos92287's Avatar
it will work with stock. just try and get one no taller than 6" or you'll need to cut some supports, but any fmic will require a little bit of trimming
Old Nov 28, 2007 | 12:05 AM
ocielz's Avatar
cool thanx for the info.
