Intermittant Check Engine Light
Old May 1, 2007 | 06:06 PM
cten2002's Avatar
Default Intermittant Check Engine Light
I need some help. I have a 1999 Audi A4 2.6, 5 speed with 85,000 miles. I've been unable to get the check engine light fixed despite nearly $700 in repairs. The car has an aftermarket Sony radio.
1/19 - Repair shop pulls code P0411/16795, replaces bad vacuum lines. CEL light is off after repair
6/21 - Repair shop pulls code for vacuum leak, replaces vacuum lines. CEL light is off again.
3/6 - Audi dealer replaces faulty speed sensor ($400) CEL light comes back on 1 week later. Dealer say radio must be pulled to diagnose.
I do nothing for several months. CEL light goes off and then comes back on.
1/27 - Repair shop pulls code 16885. CEL light is off for a couple of months during the cold weather.
CEL light is back on.
Does anyone have any recommendations? I need to smog check the car soon and can't do it unless the CEL is off.
Thanks.
Old May 1, 2007 | 07:21 PM
SacTown_Vlad's Avatar
Default RE: Intermittant Check Engine Light
if it’s on and off, go to AutoZone or any other local auto store and get VAG-COM, clear cel right before you do smog check, and return VAG-COM back to the store …
u mean 2.8 instead of 2.6 engine
Old May 3, 2007 | 07:00 PM
cten2002's Avatar
Thanks for the suggestion. Yes, 2.8.
Old May 3, 2007 | 07:41 PM
acetrebo's Avatar
Even easier, before you go to the test, pull the neg battery cable off for a minute or two.
Then hook it back up, and go and pass your test.
cw2899
May 20, 2011 05:26 PM
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
blanthony
Mar 25, 2006 01:18 PM
