It's finally done!
Old Nov 11, 2005 | 05:01 PM
ShadowUCD's Avatar
Default It's finally done!
Alpine 12 inch type R sub = $200, Alpine MRD-M605 600 Watt mono amp = $240, Stinger multiamp wiring kit + Stinger RCA interconnects + Stinger Line Out Converter + 2 Feet Stinger Pro speaker wire = $100, 6 hours of install time = free, Bass the hits like I couldn't believe = Priceless. It was a tough journey, fraught with tension and adversity, but a worth-while one. Most difficult parts were removing the ECU cover and the passenger side wall in the trunk. Having done it once, I could probably do it again in a 3rd of the time. Thanx to those from here, the zine, and audiworld for your help. The next step, after my year-long "vacation" in Iraq will be to build a fiberglass box and stick the sub in the left wall. And putting in an Alpine multichannel amp and type R speakers for the doors.
Old Nov 11, 2005 | 05:17 PM
Yuikio's Avatar
Default RE: It's finally done!
Sounds sweet. And good luck on your vacation.
Old Nov 11, 2005 | 06:19 PM
InsaneHatter's Avatar
If you got the dual voice coil version of that make sure you wire it in 2 ohm mode. you will get between 400-600W RMS depending on voltage. If you wired it 4 ohm you wont get enough wattage to that speaker. maybe 250? 300?
Those speakers can handle 500W RMS? 1000W Peak.
Did you get dual 2 ohm or dual 4 ohm voice coils?
Old Nov 11, 2005 | 09:41 PM
ShadowUCD's Avatar
I got the dual 4 ohm coils. The way I have things connected now, it definitely hits hard enough. I have to turn it way down to avoid the wrath of the MPs until I get off post.
Old Nov 12, 2005 | 11:58 AM
Jestnomen's Avatar
6th Gear
Nice, have any pictures of your install for us? When do you leave for Iraq? I'm out of here in 3 weeks myself for afghanastan.
Old Nov 12, 2005 | 01:34 PM
ShadowUCD's Avatar
Pictures will have to wait until tomorrow. The sun is already going down here in Germany. I will be gone before the end of the month.
DavidgotanAUDI
Nov 26, 2008 09:13 PM
southcoast
Feb 21, 2007 05:19 PM
eldrego
Jun 18, 2006 06:53 PM
achTTung
Nov 10, 2005 04:43 AM
RomeA4
Oct 31, 2005 03:01 PM
