jsut bought 2000 a4
Old Jan 15, 2006 | 11:51 PM
whartsoe789's Avatar
Default jsut bought 2000 a4
i jsut bought an audi a4 2000 with 90k on it. it looks to be in good physical shape. i got all the maintance records and it was well taken care of. is there anything that i should look for that could cause problems?
Old Jan 15, 2006 | 11:55 PM
Karl's Avatar
Default RE: jsut bought 2000 a4
Hi, welcome to the forum.. what kind of engine do you have? Quattro or FWD? Pics?
Old Jan 16, 2006 | 01:22 AM
flyinb501's Avatar
Make sure the timing belt has been replaced.
Old Jan 16, 2006 | 01:27 AM
PandaXpress's Avatar
Old Jan 16, 2006 | 02:06 AM
headshok2002's Avatar
If it's been well maintained, then yeah, hopefully the timing belt has been changed. If it hasnt... who knows if it's been well maintained or not!
And 90K miles... listen up for squeaky/clunky control arms! Mine are starting to go at 70K miles (105 000 km)
Old Jan 16, 2006 | 02:39 AM
Jestnomen's Avatar
6th Gear
Hey welcome to the forums. Any pictures for us?
Old Jan 16, 2006 | 10:07 AM
david9999's Avatar
Welcome to the forum
Make sure the timing belt is done. If it hasn't been changed you are on borrowed time.
Change all the fluids in the car. Transmission or gear oil, differential, rear differential, center differential.
Swap out the power steering fluid with Pentosin 11S.
Check the front control arms and tie rod ends.
Check the CV boots for cracks.
Check the brake pads for wear.
check the battery cells for electrolyte level and top up with distilled water.
Buy a VAGcom from Ross-Tech
Old Jan 16, 2006 | 02:34 PM
CRAZYHAWK's Avatar
If it's a 1.8T , check for oil sludge and use a synthetic engine oil that meets ACEA A3.
Feb 3, 2014 07:42 PM
s50swapped
Aug 22, 2008 03:25 PM
VtecLOL
Nov 11, 2007 04:55 PM
2003silvervette
Jul 1, 2006 08:04 PM
Kdog2112
Oct 18, 2005 10:51 PM
