just a cold thing?
Old Nov 10, 2007 | 07:09 PM
chaos92287's Avatar
Default just a cold thing?
i have very little experience as to how the car acts in cold weather since i've lived in south fl for 20 years (my whole life) so i was hoping some of you northern guys can help me out. the other night i drove to the gym and noticed a noise when i turned my wheels like when you have low power steering fluid. does this happen in cold weather even if the fluid is full? it was ~35 degrees. i would check my fluid level but my car is at a friends house cause i drank too much last night lol also are there any other cold specfic problems i should be aware of, so i dont freak out if something else goes wrong...
Old Nov 10, 2007 | 07:16 PM
hiwords's Avatar
Default RE: just a cold thing?
i think one thing that i noctice is, if u put the key in and turn the ign to on, wait a couple secs b4 u actually start the car. it seems to start easier that way for me. also warm the car up for at least 8 min b4 u drive it.
Old Nov 10, 2007 | 07:27 PM
oettinger1919's Avatar
SoCal Crew Member
i just had that problem and ignored it for awhile and found out that my fluid was leaking around one of the lines under the engine block. i dont know how the cold weather has anything to do with it.
Old Nov 10, 2007 | 07:30 PM
hiwords's Avatar
have u ever put an ice cube on a hot stove? u kno wut it does, it cracks. that's how the cold effects it.
Old Nov 10, 2007 | 08:35 PM
sean1.8t's Avatar
ORIGINAL: hiwords
what do you mean "warm it up" for 8 minutes before driving it? that is WAYYY to long for a warm up period. all you need to do is let the car idle for about 45 seconds to a minute. then drive the car. but DO NOT boost at all until your oil temp is higher than 150 degrees. then your engine is properly warmed up
Old Nov 11, 2007 | 08:34 AM
B6er's Avatar
ORIGINAL: sean1.8t
ORIGINAL: hiwords
x2 even when in the teens, I just let it idle down which takes 1-3 minutes dpending on temp. Even in the summer, I at least wait for the SAIP to shut off most times.
Old Nov 12, 2007 | 12:34 PM
Rob_B's Avatar
Mine did the same thing this morning. Seems the fluid contracts a bit when cold, so I added some, and it quieted down a bit. It still looks like a capuccino in the reservoir so I think it'll be a few days to work the bubbles out. Keep an eye on the level though.
Old Nov 24, 2007 | 07:27 PM
casonbush's Avatar
does it still look like a cappacino? i am having the same problem and noticed the bubbles. i had audi check it out and they said they bled the system and couldnt get the noise to duplicate. but, a day later and we are back to square one. fluid level is up to maximum though.
Old Nov 25, 2007 | 02:37 AM
96A4Owner's Avatar
I've been having the same problem with the cold, so today i picked up some power steering fluid, filled her up, and the noise disappeared. It also seems that it's much easier to turn.
Old Nov 25, 2007 | 03:01 AM
A4speed's Avatar
you probably are just starting to get low on powersteering fluid, i dont know.
also, i hate to be captain obvious here but chaos, your posts are going backwards, i saw you hit 5000
