is it just me?
Old Oct 2, 2007 | 02:31 PM
auditurbo381's Avatar
Default is it just me?
or are headliners B**** to get out and put in without damaging
Old Oct 2, 2007 | 09:40 PM
auditech79's Avatar
Default RE: is it just me?
ORIGINAL: auditurbo381
No, you just don't know what you're doing.
Old Oct 2, 2007 | 09:51 PM
you seem to be bailing my *** alot lately. thankssss♥ i cant find a decnt DIY. any tips. im trying to replace mine.
Old Oct 3, 2007 | 12:31 AM
auditech79's Avatar
Remove all the handles on the roof first, then pop out the little covers that say air bag on them and take out those screws behind those. Now you can pop off the A-pillars (which are stubborn!) use a trim panel tool or a long *** screwdriver to pry them off. Pop off the upper B pillars and let it fall with the seat belt still going through them. Then un-bolt the C and D pillars.
This is where it gets fun, put your sunfoof glass in the tilt position and go inside the car, you should see three torx bolts on each side of the sunroof glass, remove those and pull the glass out from the top.
Pop out the light covers where the sunroof switch is, there should be a couple of bolts there too, remove those. Now go back on top of the car and CAREFULLY remove the sunroof ring thats holding the center of the headliner to the sunroof rack assembly. After that is out you can pull it straight down as there is only a couple of clips holding it on.
Old Oct 3, 2007 | 01:00 AM
dont know how many times i can say it. but <b> THANK YOU!!!!
