Just ordered timing belt kit/snub
Old Sep 12, 2005 | 04:15 PM
onepoint8tee's Avatar
Default Just ordered timing belt kit/snub
Well I did it.. Ultimate timing belt kit and APR snub! I cant wait!!!!! This is like an 8hour job altogether right?
Old Sep 12, 2005 | 05:27 PM
jlaudio184's Avatar
Default RE: Just ordered timing belt kit/snub
plan on 10 hrs total for 1st timers just becasue you have to figure things out
Old Sep 12, 2005 | 07:25 PM
skidplatexa4's Avatar
It's easy to do just real time consuming. If you have access to a lift it makes it easier, and takes little less time.
Old Sep 12, 2005 | 07:35 PM
ORIGINAL: skidplatexa4
I need to drain the coolant too right? How much is Audi's coolant?
Old Sep 12, 2005 | 07:38 PM
dubiousmusic's Avatar
you dont nessesarly have to drain it you can plug it off if that makes sense
Old Sep 12, 2005 | 07:42 PM
cool. I know the radiator has to be moved, but i havent see pics of it set asside.. Is that a pita?
Old Sep 12, 2005 | 08:27 PM
duhvinci's Avatar
To make the work easy (for access to all the parts), I think that removing entire front support was easier for me (ac condenser was the only thing I moved to the side) I found this AW tech article very useful:
http://www.audiworld.com/tech/eng35.shtml
Old Sep 12, 2005 | 09:31 PM
Anyone know how long itll take for ECS to get me muh shiznit?
Old Sep 12, 2005 | 10:58 PM
ECS will have to you in about 2-3 days. Also you do have to drain the coolant to do the water pump. When you do the water pump make sure all of the old gasket is removed from the area before putting the new water pump back in.
Old Sep 12, 2005 | 11:45 PM
Thanks, that pic is hot dude.
Audiguruforyou
Sep 20, 2011 01:31 AM
sickguy
Jun 11, 2007 03:07 PM
coheed
Aug 18, 2006 04:30 AM
david9999
Sep 12, 2004 12:43 AM
