Just thinking loud !!!
Old Mar 3, 2005 | 11:25 PM
GregaXX's Avatar
Default Just thinking loud !!!
So I want to hear your opinions about boring the cylinder from 1.8l to 2.0l? Tell me why should this be done, good and bad things about this? I will run GT3071R so I want to spool it sooner like 3000 rpm, will I make it or not with boring, also changing pistons with lower compression, rods...? This is just thinking, so please give me some data, maybe some experiance.
BR,
Greg
Old Mar 4, 2005 | 12:03 AM
PandaXpress's Avatar
Default RE: Just thinking loud !!!
dont do it not safe for the engine, thinner walls and high boost
Old Mar 4, 2005 | 12:35 AM
GregaXX's Avatar
So it is better then to run on stock pistons, just lower compression (two head gaskets will do it) and change rods with Pauter rods?
Old Mar 4, 2005 | 12:44 AM
apg96's Avatar
would it be ok with no turbo cause i have a 2.8? How would my gains be?
Old Mar 4, 2005 | 12:53 AM
190/2.8 then X 3.0 about 203HP its some wut accurate
this is the theory of HP per Liter
Old Mar 4, 2005 | 12:55 AM
audiboy1618's Avatar
You can bore out to the 2.0, they make stroker kits for it. Alot of people do with big turbos. I cant say on how reliabale it would be.
Old Mar 4, 2005 | 01:00 AM
audiboy1618 when did u come back
Old Mar 4, 2005 | 01:02 AM
TomRitt's Avatar
Stroker kits are the way to go. btw u got pm with more info.
As far as the 2.8, it has thinner cyl walls than the 2.7 and is not safe to bore out. (I have no experience with this but have read it several times)
Old Mar 4, 2005 | 01:05 AM
Tom what turbo is mike running over on the zine with his stroker kit? gt30?(mike2ptzero)
Old Mar 4, 2005 | 01:17 AM
GregaXX's Avatar
Thanks I just read it ! So you are for stroker kit, maybe any argument why, what is good side of stroker kit?
