K04 & life span/reliability..
Old Mar 17, 2005 | 11:46 PM
JDCrowe's Avatar
Default K04 & life span/reliability..
so i have a time frame on my mods..
AWE GIAC chip
Bailey DV ------------- 3 mos.
AWE Borla exaust ------- 6 - 12 mos.
AWE K04 ------------- 9 - 12 mos.
so i'm not so worried about the chip or exaust.....
but the K04? my 2001 only has 33K miles on it, probobly wont have much more than 35-36K on it in 12 mos.
so even though it'll be out of warrenty, i really dont want to cut it's life-span down too much..
now i know that there's a few of you on here that are actual mechanics, and a few more that really seen to know what your talking about........... THESE are the opinions that i'm really looking for...
thanx..
Old Mar 17, 2005 | 11:52 PM
Doose's Avatar
Default RE: K04 & life span/reliability..
I've got 125,000 on mine. I chipped at about 80,000 and put the K-04 in at around 100,000. As long as you keep taking care of it you'll be fine.
Old Mar 18, 2005 | 12:47 AM
audiboy1618's Avatar
I have a ko4, it really all depends on what software you use, some of them are pretty brutal.
Old Mar 18, 2005 | 01:27 AM
audihere's Avatar
Banned
if u notice he has an 01. he has no choices unless he goes custom or uses the x chip....
Old Mar 18, 2005 | 01:40 AM
Im going custom and i have a 99.5, I just wish i was .5 year newer and have the j31 be making more torque then i could handle.Im running giac now, but going custom with them or dahlback.
Old Mar 18, 2005 | 01:49 AM
audihere's Avatar
Banned
what the p16 file not good enough for ya?
Old Mar 18, 2005 | 01:59 AM
nope, the only dif is smother torque curve, makes about the same hp as my 5bar program.
Old Mar 18, 2005 | 11:43 AM
clconversion's Avatar
the p-16 gives higher #'s doesn't it but it requires a FMIC and injectors but hey if you are going with the dalback they can program you to run the best with the mods u have now
Old Mar 18, 2005 | 06:28 PM
JDCrowe's Avatar
well, i have no intentions of using any special files or anything.......
if i understand it right the AWE K04 & Borla Exaust will put me right around 250hp, and this is abouot all i'm looking for. so i see no need for anything else...
so, the stock K04 from AWE, no files, ... is it gonna have a drastic effect on my cars life-span? Should i be weary? i do only have 35K miles on it, so putting 60-80K more miles on this car is VERY likely....
good advise only please.... if your talking out your a$$ basing your advice on "what you heard" please dont waste a post.
this is a serious question and i'm only looking for advise from people who have serious knowledge (i.e. if you backed the "turbonator" in a previous post, keep your opinion to yourself)
Old Mar 18, 2005 | 06:38 PM
Well the stoack program that comes with AWE's K04 kit is the E05 you will need this to get 250hp and to go another 60-80miles I don't see a problem as long as you keep up with your maintances and you arn't beating the hell out this thing all the time I do understand that there are going to be times that you will want to have fun but after you do make sure you let the car idle for a least a minute before you shut it off you will be ok [sm=gears.gif]
