Keyfob
Old Mar 25, 2006 | 05:31 PM
tekarchitect's Avatar
Default Keyfob
Hi there,
Sorry if this has been asked a thousand times before but I have a 2004 A4 FSI SE. UK spec. One of my keyfobs stopped working the other day. i.e it would not unlock/lock the car. Went and got my spare remote and drove to work thinking it must be the battery in the other remote. Go and buy a panasonic cr2032 replacement battery and then replace in the faulty remote. I then follow the instructions from the manual which it says to do after replacing the battery in the remote:
Re-synchronising the remote control
- If the vehicle is locked, use the key to unlock the drivers door
- Press the unlock button on the remote control
- Insert the key into the ignition and switch on the ignition
- Switch off the ignition and remove the key
- Press the unlock or the lock button
I follow this to the letter and it does not work!! In fact I tried it for about 20-30mins!!!!
Has anyone any ideas? What am I doing wrong Is this a known issue?
Thanks in advance
TeK
Old Mar 25, 2006 | 05:33 PM
black991.8tq's Avatar
Default RE: Keyfob
my remote quit working yesterday so i need an answer to this question also.
Old Mar 25, 2006 | 11:07 PM
north5995's Avatar
Default RE: Keyfob
Mine has done the same thing. It stopped working, then would spiratically work, now it has just stopped all together.
Old Mar 26, 2006 | 12:21 AM
Jestnomen's Avatar
6th Gear
Default RE: Keyfob
Hmm on mine I turn the key to the position before on, and hit the unlcok button, turn the key off and hit the unlock button and it resyncs.
Old Mar 26, 2006 | 03:08 AM
707782y's Avatar
Default RE: Keyfob
I wish you guys could fix this problem, because dealership is the only place that can get you another one fob for cars over year 2001, and they charge over 250 bucks.
Old Mar 26, 2006 | 09:37 AM
Default RE: Keyfob
Ok. I'll try that. What year is your A4?
Thanks
TeK
Old Mar 26, 2006 | 09:44 AM
Default RE: Keyfob
Sorry - just noticed the year on yours!
cheers
Old Mar 26, 2006 | 05:34 PM
Default RE: Keyfob
Hi there,
Have tried your suggestion. Can't get it to work with this either.
Shall phone the dealership in the morning.
Thanks for your help
Old Mar 29, 2006 | 01:54 AM
kshkid's Avatar
Default RE: Keyfob
Does anyone know if there are "legit" aftermarket key fobs and if so, is it worth it to buy a black keyfob and still have to take it to dealer to get coded and keyed? Thanks!
Old Mar 29, 2006 | 12:00 PM
Jestnomen's Avatar
6th Gear
Default RE: Keyfob
Depends on your year. 2000's and older it's pretty easy. Lots of them come with blank keys, so you just go get the key cut at the dealership and program it yourself. 2001 and up have an immobilizer in them that has to be programmed by the dealership afaik. That's for US keys, Europe had the immobilizer much earlier.
budnfrida
May 28, 2012 10:49 PM
kriptonik
Mar 5, 2007 04:09 AM
bigblokey0
Jun 18, 2006 05:46 PM
tekarchitect
Mar 25, 2006 05:29 PM
