ko4 effectiveness
Old Dec 9, 2005 | 09:39 PM
sada4's Avatar
Default ko4 effectiveness
would a ko4 be an effective upgrade for an automatic 1.8t?
Old Dec 9, 2005 | 09:47 PM
KelticSlob's Avatar
Default RE: ko4 effectiveness
Are you mental? You started a thread about this less than an hour ago.
Old Dec 10, 2005 | 10:06 AM
david9999's Avatar
K04 is a great bolt on upgrade.
However, you will need to get upgraded programming for the K04 to get any increase in power.
Additionally on the tiptronic you should probably get an additional tipchip for the transmission.
Additionally you will need an upgraded diverter valve, and a higher pressure fuel regulator so you don't run lean at high rpm. A low restriction exhaust is also suggested.
marker51691
Mar 3, 2010 02:10 PM
