Lame Stripe
Old Aug 6, 2006 | 02:59 PM
DaMoose's Avatar
Default Lame Stripe
My A4 has a stripe down each side of its body. My A4 is Blue and the stripe is tan about 2 mm wide and runs from the hood to the truck. Its not painted on, it seems to be a factory decal.
I think it looks stupid so I'm going to take it off. Any ideas on the best way to remove this eye sore?
Old Aug 6, 2006 | 03:01 PM
onepoint8tee's Avatar
Default RE: Lame Stripe
Get it started with a razor blade and see if you can just rip it off. If its on there real good get a hair dryer and use the razor blade some more.. just dont scratch your paint. id like to see a picture of this! post a pic of this if you can before you take it off.
Old Aug 6, 2006 | 03:37 PM
DaMoose's Avatar
But what about if once i take it off there is a smudge? What would be good for that?
Old Aug 6, 2006 | 03:43 PM
Session101's Avatar
if its a decal pinstripe...i would wet it first and clean the surface around it, and then use a hairdrier to heat up the decal
it should come off a little bit easier than just going at it
there might be a line afterwards, best to do is wax and buff the hell out of it
Old Aug 6, 2006 | 03:47 PM
techbod's Avatar
pinstripe?? heat it with a hair dryer to soften it then it will just peel off without damage to the paint work, using a blade hell no
Old Aug 6, 2006 | 07:45 PM
StevenTownsend's Avatar
i want to see i want to seeeeee
Old Aug 6, 2006 | 07:56 PM
AteUrV8's Avatar
ya thats definately a pinstripe, lol.... and i have taken pin striping off of two cars and its very easy, and takes about 10 minutes a side...
it should just peel off, just get it started with something safely, and dont create too much slack in the pinstriping when peeling it off or else it will rip and youll have to do some peeling again....
hurry up and get it off...your car will look 100x cleaner
palonisj
Jul 28, 2010 10:48 PM
Dutch05
May 19, 2008 07:49 PM
Emrtr4
Sep 16, 2006 04:28 PM
coheed
Aug 6, 2006 01:49 AM
