Launch Problems
Old Nov 3, 2006 | 01:42 AM
theguy1084's Avatar
Default Launch Problems
Well I took my car to the track today. It was my first time racing so I was kinda bad. Whats killing me is my 60 foot times because as soon as I launch the car bogs. my reaction time isnt the greatest either. .828 was my best and 10.8 in the 1/8th. I think some of my problem was the track tho. At the starting line if I was not on the brake I would slowly roll forward and I didnt want to red light. So it was kinda hard to rev it while holding the brake. I dont know maybe Ill stick to road racing..lol
Old Nov 3, 2006 | 01:44 AM
BadLuckAudi's Avatar
Default RE: Launch Problems
are you quattro or FWD ??? if your worried about rolling you could always just hold the e brake a tad with the button pushed then as soon as its close let go and go as normal
Old Nov 3, 2006 | 01:45 AM
Lazer Viking's Avatar
uh, use the ebrake ?
Old Nov 3, 2006 | 01:46 AM
theguy1084's Avatar
quattro
Old Nov 3, 2006 | 01:51 AM
acetrebo's Avatar
Put your heel on the brake and toe on the gas. I know its not as easy as it sounds, but its do-able.
You want to launch about 3k, and as soon as it catches stomp on it, and get through first as fast as you can.
That sucks the track is not level, cause normally you dont have to worry about the brake if its a flat surface.
Old Nov 3, 2006 | 01:54 AM
just like a line lock all you gotta do is hold it up a tiny bit to keep the car from rolling its not really difficult
ORIGINAL: Lazer Viking
Old Nov 3, 2006 | 01:55 AM
i stay away from the drags... because, well its a 3800 pound car haha
Old Nov 3, 2006 | 01:58 AM
acetrebo's Avatar
ORIGINAL: BadLuckAudi
HMmm, 1 hand on the steering wheel, one hand on the gear shift, third hand on the ebrake, somethings not right here.......
I think i'll use my right foot instead.
Old Nov 3, 2006 | 01:59 AM
why does your hand have to be on the shifter???? theres no need to shift the second you start you have more than enough time to go from brake to shifter to shift to second
ORIGINAL: acetrebo
Old Nov 3, 2006 | 02:06 AM
acetrebo's Avatar
true, you would have time to make the switch.
I think ultimately I would find a track that is level so I didnt have to worry about it.
I still think I would use my foot instead, but what ever works for each driver is fine. My first gear seems so short, I want to be ready to shift!
