LEAKING
Okay so after doing my brakes now any time I park when I come back to my car I can expect to find a nice puddle of this black liquid. Its not oil and its over to the left towards the front of the car. Any ideas?
If its black and not oil maybe its brake fluid leaking into a fender or something and picking up crap from the road while you drive then drips out while your parked. Or if its dripping and running across something dirty like the bottom of the oil pan before you see it.
Thats real bad.
You should pull your back wheels off and see where its leaking from, before your brakes fail on you completely.
Probably either a bad caliper, or you have a hole in your brake line, or the connection is not tight and leaking.
Have someone push the brake pedal while you are looking at it, you should be able to see where its coming from pretty easily.
Bryceaudi
Jul 31, 2007 03:42 AM
