Lighter flywheel=increased acceleration????
Old Oct 30, 2007 | 06:53 PM
crayzdavy's Avatar
Default Lighter flywheel=increased acceleration????
I've read that a lighter flywheel will increase acceleration on any vehicle. Apparently this has been known for some time according to what is out there. Although it does not increase actual horsepower (obviously, it (flywheel) does absorb energy during acceleraton, so a lighter flywheel will increase acceration right?
This is a thread from a BMW site below
http://www.unofficialbmw.com/e36/per...l_effects.html
this is from a toyota site
http://www.geocities.com/motorcity/7177/flywheel.html
Old Oct 30, 2007 | 07:06 PM
cincyTT's Avatar
I'm make believe
Default RE: Lighter flywheel=increased acceleration????
Yes, you will accelerate faster due to a lower rotating mass. Import turner or one of the mags claim a couple hp for every 1lb removed from the fw.
Old Oct 30, 2007 | 07:10 PM
crayzdavy's Avatar
Well my feeling on it is if CINCYTT said it's true. IT'S TRUE!
Any advice on lighter than stock flywheels out there?? I'm not looking for a high priced clutch package as I have no need due to increased horsepower. I have a 12v!!!
Old Oct 30, 2007 | 07:27 PM
ImTheDevil's Avatar
It is true, and you'll also get the benefit of a quicker-revving engine as well, since there's less inertia on a lightweight FW to overcome. There may be a little bit of a learning curve when you first drive with it though - that quickness in revving works both in increasing and decreasing revs. When you go to take off, once you begin to engage the clutch, your revs will drop more quickly before you get on the gas, so you may have a little bit of lurching until you learn the "new" way the engine engages. It won't take long to get it though - took me about 10 minutes of driving in town in my Z to learn the feel of the light FW and UD pulley. And the engine does feel more responsive, make no doubt about it. I felt like the biggest gain in response was cruising on the highway and accelerating in-gear - seemed to pick up noticeably more quickly.
Old Oct 30, 2007 | 07:28 PM
cincyTT's Avatar
I'm make believe
Did you really need to make another thread? Just asking. No idea whats out there for a 12v but people probably arent going to swap clutches just for a lighter fw. Maybe something to do if the clutch goes, but not if its in full working order, thats not really cost effect for the small gains.
Old Oct 30, 2007 | 07:33 PM
hiwords's Avatar
crayzdavy, u can always follow oneg and use NOS. hopefully his setup works great and i think i might do it too lol
onepoint8tee's Avatar
Which thread do you want locked? Your choice
Old Oct 30, 2007 | 07:41 PM
crayzdavy's Avatar
Sorry..that was retarded!! Lock the other one
Old Oct 30, 2007 | 09:10 PM
AteUrV8's Avatar
lol, onepoint8 gave hima choice... such a sweet fellow.
get that flywheel and lemme know how it goes, i plan on doing it..
but than again I plan on doing a lot of things..
Old Oct 30, 2007 | 10:31 PM
ImTheDevil's Avatar
Gotta agree there. Here's an idea - start running the nitrous, and when your clutch says "peace", then upgrade that along with the flywheel
