limp mode?
Old Jun 11, 2005 | 03:56 AM
flyinb501's Avatar
Default limp mode?
The last couple nights while getting on the freeway and acclerating hard(almost hitting redline in second and third) the car all of a sudden was only boosting 5 psi. Went back to normal after car was turned off and on. I assume it went in to limp mode. What causes this? And what exactly is limp mode?
Old Jun 11, 2005 | 04:03 AM
black991.8tq's Avatar
Default RE: limp mode?
are u runnion a stock n75?
Old Jun 11, 2005 | 04:07 AM
flyinb501's Avatar
Yeah I guess, but I don't know exactly what that is. I've seen the term thrown around though. I have had the chip for a couple months but this is the first time this has happened. I rarely run the rpm's up that high though so I'm guessing that has something to do w/ it.
Old Jun 11, 2005 | 04:11 AM
how high is high, when u get a chip it takes away ur stock rev limiter so u can go higher rpm. what u shiftn at
Old Jun 11, 2005 | 05:55 AM
Dave666's Avatar
I have also heard the term. Cant really explain it well anough though.
Call the place you got it from .
Old Jun 11, 2005 | 09:38 AM
david9999's Avatar
N75 is the valve which controls the opening of the waste gate.
At high RPM, is your PSI slowly dropping off. It could be that the K03 is starting to run out of steam.
Once the car is running at lower RPM, is the boost normal or is it still low?
Any codes? Could your MAF be starting to go and Air metering sending the wrong signals to your car?
If it recurs check with your tuner.
Old Jun 11, 2005 | 05:10 PM
flyinb501's Avatar
PSI holds at 15. Max boost occurs at 3000 rpm. MAF was replaced a couple of months ago. Is an aftermarket N75 an easy diy? How much are they?
Old Jun 11, 2005 | 06:07 PM
david9999's Avatar
Easy DIY (just don't drop it). Cost is 70-90 dollars.
that may not be the problem though. check for any codes that may be stored?
Old Jun 12, 2005 | 03:02 AM
flyinb501's Avatar
Alright I guess I was wrong, the psi is slowly dropping off at high rpm. Does this mean my turbo is almost done?
Old Jun 12, 2005 | 03:15 AM
audiboy1618's Avatar
Limp mode is caused by over boosting or leaning out up top in most cases. Ive boosted to 29psi and stilll never went into limp.
