Limp Mode? Maybe? I dont know
Old Mar 7, 2007 | 01:43 AM
onepoint8tee's Avatar
Default RE: Limp Mode? Maybe? I dont know
yeah, you should definately see 8 psi, and sometimeseven spikes of 10psi if youre lucky. It does sound like limp mode.
Old Mar 7, 2007 | 01:45 AM
Bondga's Avatar
ok well i'll use vag and clear the codes tommorow then i'll disconnect the maf and see what happens.
Old Mar 7, 2007 | 02:17 AM
turbo kraut's Avatar
Tech Guru
dude, sounds like my problem, i was running strong, then boom, ":limp" mode, bought a guage and i ran 5 psi, so i get it cleared and was spikinbg about 10, setteling about 7 or 8
a bad maf won't make you run limp, from what the audi mechanic told me, my problem was a bad thrust sensor, but is your code 0171? that is what i had
Old Mar 7, 2007 | 02:39 AM
Bondga's Avatar
tthe only current code i get from the engine is 17536, Fuel trim bank 1, system to lean
Old Mar 7, 2007 | 08:56 AM
x1rider's Avatar
I think it's probably the CEL as well. I had a similar code happen to me except mine was running too rich. The CEL would not even light up and I would go into limp mode (I have GIAC FXKO3 with Genesis injectors so I would go down from 19-20psi to 5psi). When scanning the car, I would see the DTC but no CEL. One time I had my girlfriend clear the code while I was driving and the boost came back instantaneously..... until I got the DTC again!!!
Old Mar 7, 2007 | 12:39 PM
ORIGINAL: turbo kraut
Yes a bad maf will make you go into limp mode. A bad maf can cause you to run lean. Running lean can cause detonation wich kills engines. I went into limp mode when my maf was dying.
ORIGINAL: x1rider
You shouldnt do that, you can kill the ecu by doing that.
Old Mar 7, 2007 | 01:27 PM
x1rider's Avatar
Quote (as you can see, I haven't figured that one out yet!)
Ha Ha, I know, it was a quick one time experiment!!!
Old Mar 7, 2007 | 08:22 PM
  #18
Audi_Skydiver's Avatar
I keep hearing people say detonation, WHAT IS THAT???? I know thats a dumb question but I truly don't know. Thanks
Josh
Old Mar 7, 2007 | 08:45 PM
  #19
ORIGINAL: ThePaintballGuy
Josh
P.S. Srry to jack the thread.
Damn dude... Try a search every once in a while.
Old Mar 7, 2007 | 08:46 PM
  #20
I know, but does it really kill you to say detonation is...?
Josh
