a little help on fluid weights and amounts
Old Aug 22, 2006 | 04:23 PM
1.84life's Avatar
Default a little help on fluid weights and amounts
hey guys i have a 2000 2.8 30v quattro 5 speed
i dont have a manual and i could'nt find these anywhere plus i wanted to see what everyone on here reccomended:
tranny fluid weight and amount:
quattro weight and amount:
brake fluid (kind and amount)
coolant.. what type.. how much ..
im at a 100,000 and before the weather the weather gets cold again im goin to do all of these because i doubt any of them have every been changed.. so if anyone could help out with what type of fluids you would use, and what weights and amounts to use..
thanks =]
Old Aug 22, 2006 | 05:26 PM
Trey25's Avatar
Default RE: a little help on fluid weights and amounts
Audi does not specify a change interval for the tranny and diffs, but I'd recommend changing them anyways. For the trans its 75W as well as the diffs (the center diff should be same too). Brake fluid is dot 4+ or dot 4 super, NOTHING else. Use the G12 coolant from audi, don't mix with the regular stuff. I'd recommend either mobil1, amsoil, royal purple for all the oils, that if you can find them. The brake fluid you can get a dealership or here.
Old Aug 22, 2006 | 06:12 PM
InsaneHatter's Avatar
Tranny: 75W90 G4 Compatible. Amsoil 75W90 is good.
Rear Differentail: Same as above.
Brake/Clutch: Super DOT 4 or above, stated by audi: dry boiling/wet boiling of standard DOT4 does not meet the requirements.
Coolant: G12 Coolant (its pink) 50/50 mix w/ Distilled water.
This is for a Manual Tranny w/ Quattro.
Auto Tranny:
Replace 75w90 Tranny w/ ATF AE
Also needed:
Differential, Front : 75W90
Transfer Case: 75W90
CAPACITIES
Engine, with filter..........6.0 quarts[1]
Cooling System, 2.8L Initial Fill..........6.4 quarts
Automatic Transmission, Initial Fill..........3.7 quarts[2][3]
Automatic Transmission, Total Fill..........9.5 quarts
Manual Transmission, 01E..........4.9 pints
Manual Transmission, 01A..........5.7 pints
Manual Transmission, 6-SPD..........4.9 pints
Manual Transmission, 5-SPD..........5.7 pints
Differential, with AT Front..........1.7 pints
Differential, Rear..........3.8 pints
Transfer Case,CDIFF..........1.7 pints
Mikael116
Mar 13, 2012 03:41 AM
kemp_travis
Sep 21, 2007 08:46 AM
Artrip
Aug 28, 2007 06:28 PM
jnielsen
Aug 23, 2007 11:56 AM
MoritzCH
Jul 26, 2007 03:28 PM
