LMAO Mod this!!!
i'm sorry I still don't get it. what exactly does it do? performance gains? i think i'm confused this is the first i've heard of this. thanks.
edit: as far as this mod is concerned... do you think instead of taking out my fog light I could cut a hole in the black plastic lower grill insert (similiar to the way it is on the intercooler side) and run a pipe up there (when I get an intake)? or is it too tight of a space to run the pipe?
ORIGINAL: FasterA4ThanUrs
like in the STI on the top mount. its exactly what it sounds like...just like your windshield washer spray nozzles. but in the subaru they have their own fill tank.
ORIGINAL: smokeU
can someone explain this intercooler spray?
no water wont get in to your car because your charge system is closed unless you have a leak. the water only sprays on the fmic and none gets in. my ic spray comes stock on my car
Do you have a wider abgle pic of the car. I'm thinking that might not be noticable.
You know, computer fans work on 12vdc. I was thinking of rigging something up the would blow cool air onto the oil lines above the turbo for a few minutes after shutdown. Maybe a large volume CPU fan is what you are looking for.
are you talking about my mod? or the water sprayer?? If you are referring to my car.. im not to worried abou the looks.. as this is only something i will put in on track days
ORIGINAL: gregp1962
